Since yesterday is my version of Audirvana 3.5 in the German language. Normally I use English version. Can anybody tell me how to change.
I believe the language used for Audirvana is the system (Windows or MacOS) language. Then to change the language in Audirvana, you have to change the system language. Someone correct me I’m wrong.
Thank You for your help and the answer. You are right, in the system preferance by language and region you can change the language per app.
