Click sound before every new track
… even though itĀ“s from the same album, and therefore no sample change to blame.
No click when Studio is playing the Qobuz radio, but it clicks when I play from a Qobuz playlist
Hello @KnockKnock,
Can you send us a copy of the ā€œDebug Infoā€ when you have this issue? You can get it in Audirvana Settings>My account
Audirvana Studio 1.13.3 (11303)
macOS Version 12.4 (Build 21F79) with 16GB physical RAM
Connected account of : xxx
	AU plugin #0: Effect - Dirac Research DiracLiveProcessor ()
	AU plugin #1: Effect - A1AUDIO.de A1StereoControl ()
	AU plugin #2: Effect - Tokyo Dawn Labs TDR Nova ()
	AU plugin #3: None
Phase minimum phase
SW volume control: ON
AUTO: /Volumes/Seagate5TBClone/ROON MusicFilesSeagate
Library database path: /Users/kurtlassen/Library/Application Support/Audirvana/AudirvanaDatabase.sqlite
Listening on 127.0.0.1 on port 53604
M2TECH HIFACE EVO TWO
Model UID:HiFace Evo Two:249C:9315
UID:AppleUSBAudioEngine:M2Tech:HiFace Evo Two:14100000:1,2
Device: 2ch Mixable linear PCM Interleaved 32bits little endian Signed Float, 8 bytes per frame 96kHz
Active Sample Rate: 96kHz
Hog Mode is on
Sample rate switching latency: 1.5s
ID 0x47 Built-in Output
Model Name: Apple Inc. Built-in Output
Model UID: AppleHDA:16
UID: AppleHDAEngineOutput:1F,3,0,1,1:0
3 available sample rates up to 96000Hz
Stream ID 0x48 2 channels starting at 1
3 virtual formats:
3 physical formats
Local devices found : 4
Device #0: ID 0x47 Built-in Output Manufacturer: Apple Inc. Model UID: AppleHDA:16 UID: AppleHDAEngineOutput:1F,3,0,1,1:0 Model Name: Apple Inc. Built-in Output
Device #1: ID 0x3b Explorer² USB DAC Manufacturer: Meridian Model UID: Explorer² USB DAC:1CBA:0031 UID: AppleUSBAudioEngine:Meridian:Explorer² USB DAC:009898A8:1 Model Name: Meridian Explorer² USB DAC
Device #2: ID 0x35 eqMac Manufacturer: Bitgapp Model UID: EQMDeviceModelUID UID: EQMDevice Model Name: Bitgapp eqMac
Device #3: ID 0x2f Dirac Virtual Audio Device Manufacturer: Dirac Research AB Model UID: com.dirac.vad_ModelUID UID: com.dirac.vad_UID Model Name: Dirac Research AB Dirac Virtual Audio Device
Do you have the same issue with upsampling disabled?
Hello, can you please try to play a track for testing purpose without plugin activated?
Hi all. When I disable upsampling the click is gone! Thanks
Correction: The click was gone for a few minutes. Then it was back again. I turned of AU“s, and now the click is gone. Turned on AU`s, click is back. I guess I have to live with it
or check your plugins… they might have an update maybe? or just remove the realtime mode in plugins prefs and see
:notes: :eye: :headphones: :eye: :notes:…
The ā€œclicksā€ could be digital ā€˜overs’… The signal is over-reaching the limits of the data-path dynamic range and or the DAC architecture dynamic range… Plug-ins will add bits (gain)… this must be managed at the output, If there is no problem with the plug-in(s) themselves… try reducing the gain of your output by 6dB to 12dB and see if you still get the clicking…
Just like any audio system, gain must be managed correctly, and with digital-audio ā€˜overs’ these are spurious and related to dynamic range… the ā€œclickingā€ noise is the audio-signal data being truncated by the playback system/device data-handling architecture. You may have to reduce the gain of each plug-in to keep from overloading the next in line and the final plug-in…
Try adding each plug-in, one at a time to see if each one is working properly and you are managing the levels between the plug-ins correctly.
Hi Agoldnear (nice nick BTW). Yes that might be it, will check this later and post you. Thanx. :wink:
The clicks are not related to levels, I turned everything down, no change, I played with the setting in the ā€œProcessingā€ tab, itĀ“s the AU units yes, BUT not them, actually, itĀ“s the ā€œReal Time Controlā€ see picture, When I turn that off I have no clicks anymore. Nice, BUT then I can not control my AUĀ“s and I need that feature a lot. Thanks K
Did anyone get a solution for this? (RealTime Control is the bad guy)
Any solution on this one? best K
Hi @KnockKnock sorry for the very late reply.
Have you tried to only have one plugin at a time while playing to check if it’s not coming from one of them?
Hi Antoine
Yes, I tried that. It is not the plug-ins, I tried them one after one. It is when I turn off the Realtime Control. But I need that feature, as I use Dirac and switch between presets. best KK
