I hear clicks throughout playback of DSD256. I am playing the DSD256 files on my MacBook Pro running running macOS 11.7 with 16 Gig of memory. The DAC I am using is the Macintosh DA2 on a Macintosh integrated amplifier. The files were downloaded from NativeDSD. Any ideas as to the culprit of the clicks and how to eliminate them?
Do the clicks happen randomly or at a specific time in the file(s) ?.. Initially, try dropping your output volume in Audirvana Studio -3dB… see if this clears the clicks… Otherwise post your debug info here (remove your IP address, etc)
I dropped the volume -3dB and I still hear clicks. The clicks are heard randomly and are low volume. I have used several DSD256 files from several sources. Here is the debug info:
Audirvana Studio 1.14.0 (11400)
macOS Version 11.7 (Build 20G817) with 16GB physical RAM
Connected account of : B B
AUTO: /Users/BB/Music/NativeDSD
iTunes/Music library synchronization: last synchronized on Mon Oct 3 17:36:40 2022
Library database path: /Users/BB/Library/Application Support/Audirvana/AudirvanaDatabase.sqlite
Listening on 127.0.0.1 on port 54587
DA2 MCINTOSH
Model UID:McIntosh:2AFD:000B
UID:AppleUSBAudioEngine:DA2:McIntosh:14200000:1
Device: 2ch Non-mixable linear PCM Interleaved 24bits little endian Signed Integer, 8 bytes per frame 705.6kHz
Active Sample Rate: 705.6kHz
Hog Mode is on
ID 0x70 McIntosh
Manufacturer: DA2
Model Name: DA2 McIntosh
Model UID: McIntosh:2AFD:000B
UID: AppleUSBAudioEngine:DA2:McIntosh:14200000:1
Stream ID 0x71 2 channels starting at 1
30 virtual formats:
40 physical formats
2 ch Mixable linear PCM Interleaved 16 little endian Signed Integer 768kHz
Local devices found : 8
Device #0: ID 0x54 Apowersoft_AudioDevice Manufacturer: ma++ ingalls for Cycling '74 Model UID: com_apowersoft_driver_ApowersoftDevice:Soundflower UID: ApowersoftEngine:0 Model Name: ma++ ingalls for Cycling '74 Apowersoft_AudioDevice
Device #1: ID 0x66 Built-in Output Manufacturer: Apple Inc. Model UID: AppleHDA:93 UID: AppleHDAEngineOutput:1B,0,1,1:0 Model Name: Apple Inc. Built-in Output
Device #2: ID 0x70 McIntosh Manufacturer: DA2 Model UID: McIntosh:2AFD:000B UID: AppleUSBAudioEngine:DA2:McIntosh:14200000:1 Model Name: DA2 McIntosh
Device #3: ID 0x3c BlackHole 16ch Manufacturer: Existential Audio Inc. Model UID: BlackHole_ModelUID UID: BlackHole_UID Model Name: Existential Audio Inc. BlackHole 16ch
Device #4: ID 0x45 Microsoft Teams Audio Manufacturer: Microsoft Corp. Model UID: MSLoopbackDriverDevice_ModelUID UID: MSLoopbackDriverDevice_UID Model Name: Microsoft Corp. Microsoft Teams Audio
Device #5: ID 0x2f Pro Tools Aggregate I/O Manufacturer: Apple Inc. Model UID: com.Avid.ProToolsAnalogIOAggregateDevice UID: com.Avid.ProToolsAnalogIOAggregateDevice Model Name: Apple Inc. Pro Tools Aggregate I/O
Device #6: ID 0x4e ZoomAudioDevice Manufacturer: zoom.us Model UID: zoom.us.zoomaudiodevice UID: zoom.us.zoomaudiodevice.001 Model Name: zoom.us ZoomAudioDevice
Device #7: ID 0x35 BlackHole Input Manufacturer: Apple Inc. Model UID: ~:AMS2_Aggregate:0 UID: ~:AMS2_Aggregate:0 Model Name: Apple Inc. BlackHole Input
What happens when you remove Soundflower and BlackHole, the PTools aggregate device and the Zoom device, from the signal flow and use a simple Audirvana to the DA2 set-up/configuration?
I removed the extra devices including Zoom Audio and Microsoft Teams and still have the clicks.
Please post the debug info showing the conditions with the simple Audirvana > D2 configuration.
Per track: OFF
No plugin active
SW volume control: ON
Listening on 127.0.0.1 on port 49492
Max. memory for audio buffers: 3988MB
DA2 MCINTOSH
Hog Mode is on
ID 0x35 McIntosh
Manufacturer: DA2
Stream ID 0x36 2 channels starting at 1
30 virtual formats:
40 physical formats
Local devices found : 3
Device #0: ID 0x2a Apowersoft_AudioDevice Manufacturer: ma++ ingalls for Cycling '74 Model UID: com_apowersoft_driver_ApowersoftDevice:Soundflower UID: ApowersoftEngine:0 Model Name: ma++ ingalls for Cycling '74 Apowersoft_AudioDevice
Device #1: ID 0x3f Built-in Output Manufacturer: Apple Inc. Model UID: AppleHDA:93 UID: AppleHDAEngineOutput:1B,0,1,1:0 Model Name: Apple Inc. Built-in Output
Device #2: ID 0x35 McIntosh Manufacturer: DA2 Model UID: McIntosh:2AFD:000B UID: AppleUSBAudioEngine:DA2:McIntosh:14200000:1 Model Name: DA2 McIntosh
put your memory buffer at 13000 instead of 3988
@RunHomeSlow is giving you good advice to increase the pre-load buffer allocation… However, you don’t have a clean audio path with Apowersoft and Cycling '74 and Soundflower… Also try disabling ‘integer mode’… it really isn’t buying you anything… and try limiting the bit-depth to 24 bits.
The least memory a new Apple Silicon-based Mac comes with is 8GB…
This article may help you get a picture on your RAM usage when playing those files:
Check out “Part 2. How Do I Know if I Need More RAM Mac?”
11.2 MHz DSD256 is a data hog in DoP1.1… very large files to buffer… You could try native DSD256 playback if your DAC supports it… make sure your network is capable of transmitting the high-sample-rate packet density without choking… maybe this is a network issue…
The Audirvana Studio “process” is using approximately 2 GB of system memory, In my case, where all PCMxxx and DXDxxx, is processed using an HTRF virtualization plug-in for headphones, that is subsequently up-sampled/modulated in SoX to DSD128 .
The problem has been resolved or has significantly been diminished. I am not hearing as many clicks or any at all. The extraneous sound devices (Apowersoft, soundflower, cycling, etc.) were removed. I had removed them but not completely and had to remove the Apowersoft*.k file from the shared folder.
I increased the buffer size and didn’t observe any improvement.
My MacBook is 2014 with a 3GHz Intel i7 processor and 16GB of memory.
I do not hear any difference in sound quality between DSD128 and DSD256. I just did not expect DSD256 to sound worse than DSD128! This was purely a technical exercise.
Audirvana and Roon players had the DSD256 click issue. Both no longer have the click issue once Apowersoft was completely removed.
I suspect the root cause of the issue is processing power of my Mac and the macOS.
I am going to test with a Windows PC in the near future to test DSD256 and DSD512.
Thanks to everyone for helping - especially Agoldnear and Runhomeslow!
Here is the final debug:
Per track: OFF
No plugin active
Listening on 127.0.0.1 on port 50748
Max. memory for audio buffers: 12824MB
DA2 MCINTOSH
Hog Mode is on
Limit bitdepth to 24bit: ON
ID 0x2b McIntosh
Manufacturer: DA2
Audio buffer frame size : 212 to 4096 frames
Stream ID 0x2c 2 channels starting at 1
30 virtual formats:
40 physical formats
Device #0: ID 0x35 Built-in Output Manufacturer: Apple Inc. Model UID: AppleHDA:93 UID: AppleHDAEngineOutput:1B,0,1,1:0 Model Name: Apple Inc. Built-in Output
Device #1: ID 0x2b McIntosh Manufacturer: DA2 Model UID: McIntosh:2AFD:000B UID: AppleUSBAudioEngine:DA2:McIntosh:14200000:1 Model Name: DA2 McIntosh
UPnP devices found : 1
Device #0: ID 0x0 Basement TV UID: uuid:23456789-1234-1010-8000-F84E1745F7F8 Location: http://192.168.0.48:52323/MediaRenderer.xml
It is most likely due to how those audio-routing applications interfere with Audirvana and Roon API’s on the Core Audio path and memory allocation and the SDD/HDD storage transfer throughput/speed demand… I believe you need a very clean and fast playback platform for flawless DSD256 and DSD512 auditioning.
Unless you are a producer or recording engineer working in the DSDxxx realm, DSD sample-rates above 5.6MHz DSD128 just don’t make sense… The Nyquist frequency of a 5.6Mz signal is 2.8MHz ! … My DAC does not allow application of it’s FIR filter options at this sample-rate because the Nyquist Fs is so far out of the range of human hearing! … As an archival medium DSD256 or DSD512 sample-rates is questionable, they are data-hogs… However, given these recordings exist, albeit very esoteric and limited at best… if the production is done natively at 11.2MHz or 22.4MHz it has the potential to capture a very focused recording of an acoustic performance that can be modulated to DSD128 with great fidelity… I personally find that trying to modulate PCMxxx or DXD to DSD sample-rates above 5.6Mz is pointless…
