Hello,
my problem is that the column width in Audirvana Studio while browsing through the Qobuz Liberay always shrink down to its minimum sizes to each column (see red circle on the picture)
Is there a workaround for this problem?
Thank you
Hello,
Thank you
Hello @Msav,
if you click on Alle anzeigen and change the width of column, if you go back to this view, do you still get your column width shrink ?
I have the same problem. Its been like it since the trial of Audirvana Studio. When I click view all I change the cloumn width but it does not save. It shrinks back everytime I start Audirvana.
Are you using Windows 10 and Qobuz connected?
Yes, I am using Win10 and Qobuz connected.
I changed my language in Audirvana Studio from German to English.
As you can see in my pictures below, Audirvana can held my changes in column width if i changed it manually under “See all” and go back (see green rectangle on Picture 3). But unfortunately only temporarily.
If I click on any Artist on “Similar Artist” (see orange arrows on picture 3) the column width will get lost again after i switched to another artist (see red circle on picture 4).
But fortunately the column width of Albums (see green rectangle picture 5) seems not to be affected form this issue.
Whats annoying me the most is that under my “Favorite” Songs this column width issue is also present (red circle on picture 6)
I have been able to reproduce the issue on my side with multiple attempts. I will need to check with Damien if he’s also able to reproduce the issue easily to fix it once and for all.
Hi team,
Not every time (you will see that in the video example), the column’s size in Qobuz linked tracks is resetted.
It’s very annoying…
Video example:
https://drive.google.com/file/d/106hLj9Wfqr57Yte0Ms1NPMJOQWPZfooS/view?usp=sharing
Thanks in advance !
This also happens to me but only occasionally. It started when the option to make text larger was introduced. If that option is selected it nearly always happens.
Still happening to me also. : (
Track info is all abbreviated and undecipherable ,Please explain method to expand. Thanks
Click on the short vertical lines between the sections and drag to where you want them so that you can see as much of the listing as you want. Same as altering the column width in Excel. After shutting down and restarting Studio it may revert to truncated form though. Still awaiting a fix but I think the engineers are on it.
My first impression with the new Version 1.8.5 is that my problem was solved by you.
Thank you.
Early days, but 1.8.5 does look to have fixed the column width glitch.
All seems to be much better now, Thanks
