There are very few informations on the net, someone says it works.
But I think it should be better to ask (or try if possible) a dealer or, better, Chord.
It is not a cheap component …
There is a good chance it will work. Chord has decent UPnP implementation and it’s a good device. I would take the risk, especially if you already own the Hugo2.
I have a Chord Poly and Mojo, so whilst not the same as the Hugo & 2Go, both have similar capabilities, albeit with a different sound signature (and price) etc…
They both support UPNP/DLNA, and that’s the way i have my Poly/Mojo working with Audirvana.
There’s a ‘Play Mode’ setting in the ‘GoFigure’ app you use to configure the Poly and 2Go… either ‘Roon’ or ‘Everything Else’… Roon is obviously for enabling the Poly/2Go to be in RAAT protocol mode, while ‘Everything Else’ is for the UPNP/DLNA protocol.
Hope that makes sense. You just need a bluetooth enabled device (phone/tablet) to control the Poly/2Go via the ‘GoFigure’ app.
I would like to keep using the DAC I have an upgrade another time in the future.
Want a dedicated streaming device to replace my Mac Mini.
Al looking into the 2go and 2U.
I really do not see why one would need to be shackled having to use specific software by a manufacture of the player.
As you know,
Most other companies do so.
Audirvana is an excellent product.
I also believe that spending a significant amount of money on a life time subscription of another such product is waste since I do not feel all these companies might not be around far in the future.
Audirnavana Etc. has very reasonable pricing.
The Chord does need GoFig. app to set it up.
This was on of my questions of how to set it up for Roon or other.
I would have hoped I Could avoid BT but this only seem to be for the connection.
This would not be in the signal chain.
Of course I Pad has BT as many other devices do.
There are not to many choices on the market for what I am looking for,
no Dac, No drive Etc.
Of course most need to be used with their own software.
I think Chord are very good products and I have a very good support person if I need help setting it up Etc.
But he was not sure about how to answer my question about Audirvana neither was the distributor.
yes, @mrpanda, bluetooth is only required when making any changes to the settings in the GoFigure app… once you make those changes you can disable bluetooth again, and just enjoy listening to your music via Audirvana app.
If you wanted to switch sources to any music you might have stored on the memory card inserted into the 2Go / Poly, then this can also be done via Audirvana (choose ‘local’ option instead of Tidal/Qobuz), or you could use the GoFigure app for that too… or use the app to listen to internet radio stations also.
yes, if you just want a networked streamer to then connect via optical or usb to a dac, there are lots of options, including a Raspberry-Pi based solution which has several good reviews and plenty of videos available to help build/configure it if required.
Maybe it’s different for 2Go, but for Poly bluetooth is needed if you wanted to use the GoFigure app to configure the Poly, then this is the reason for enabling bluetooth, as the GoFigure app works over bluetooth. Maybe the 2Go config works over wifi?
So, for Poly, it’s not needed all the time, but only needed when you want to change the configuration, and you need to use the GoFigure app.
