Thanks!
For your info, here is what has been obtained during a test with tracks of that album (Log from Audirvana) when trying to play the first track of the Callas album:
2023-08-16 15:01:06.991 [debug]: UPnP Success setting AVTransportURI to http://192.168.1.16:49152/audirvana/audio_f_41.wav
2023-08-16 15:01:06.996 [debug]: UPnP Send info for file audio_f_41.wav from buffer 0 trackId 41
2023-08-16 15:01:06.996 [debug]: UPnP open file /audirvana/audio_f_41.wav
2023-08-16 15:01:06.996 [debug]: UPnP sent WAVE header with fileLength 177239084 audio data 177239040 from buffer 0 trackId 41
2023-08-16 15:01:06.996 [debug]: UPnP received audio data request from 0 for 1048532 loaded 20160000 from buffer 0 trackId 41
2023-08-16 15:01:06.996 [debug]: UPnP sending audio from 0:0 playing 0:0 loaded to 0:35 from 0 for 1048532 requested 1048532 loaded 20160000 from buffer 0 trackId 41
2023-08-16 15:01:06.999 [debug]: UPnP Send info for file audio_f_41.wav from buffer 0 trackId 41
2023-08-16 15:01:07.000 [debug]: UPnP send setNextAVTransportURI for track Otello, Act 4: “Piangea cantando” (Willow Song) (Desdemona)
2023-08-16 15:01:07.000 [debug]: UPnP Received AVTransportURI change to http://192.168.1.16:49152/audirvana/audio_f_41.wav
2023-08-16 15:01:07.000 [error]: UPnP AVTransport event: can’t parse filename http://192.168.1.16:49152/audirvana/audio_f_41.wav for new AVTransportURI
2023-08-16 15:01:07.571 [debug]: UPnP Success setting NextAVTransportURI to http://192.168.1.16:49152/audirvana/audio_f_42.wav
2023-08-16 15:01:13.360 [debug]: UPnP Success sending Pause request
2023-08-16 15:01:15.583 [debug]: UPnP Exiting playing start polling loop with 39 attempts remaining
2023-08-16 15:01:15.609 [debug]: UPnP Exiting playing start polling loop with 8 attempts remaining
2023-08-16 15:01:15.746 [error]: UPnP Error 501 setting NextAVTransportURI to on instance 0
2023-08-16 15:01:15.746 [warning]: UPnP Error resetting NextAVTransportURI when stopping
2023-08-16 15:01:15.751 [error]: UPnP Error 501 setting AVTransportURI to on instance 0
2023-08-16 15:01:15.751 [warning]: UPnP Error resetting AVTransportURI when stopping
2023-08-16 15:01:19.864 [debug]: UPnP device discarded because missing AVTransport service: uuid:0
