Audirvana is connected to the Mutec but does not start to play.
Audirvana Mac Version 3.5.31 (3561)
macOS 10.15.3 with 8192MB RAM
Per track: OFF
Replay Gain: by album
Sync list: 2 folders
AUTO: /Volumes/Datengrab/Musik
AUTO: /Volumes/Datengrab/Musik_mp3
Library database path: /Users/joey/Library/Application Support/Audirvana/AudirvanaPlusDatabaseV2.sqlite
Qobuz: Connected as Qobuz Hi-Fi
MC-1.2 USB 2.0
Model UID:MC-1.2 USB 2.0:29A2:0085
UID:AppleUSBAudioEngine:MUTEC:MC-1.2 USB 2.0:14100000:1,2
Device: 2ch Non-mixable linear PCM Interleaved 24bits little endian Signed Integer, 8 bytes per frame 48kHz
Hog Mode is on
Sample rate switching latency: 2s
Limit bitdepth to 24bit: ON
ID 0x4a MC-1.2 USB 2.0 Manufacturer:MUTEC
Model UID:MC-1.2 USB 2.0:29A2:0085 UID:AppleUSBAudioEngine:MUTEC:MC-1.2 USB 2.0:14100000:1,2
Stream ID 0x4b 2 channels starting at 1
18 virtual formats:
24 physical formats
Device #0: ID 0x30 Built-in Output Manufacturer: Apple Inc. Model UID: AppleHDA:59 UID: AppleHDAEngineOutput:1B,0,1,1:0
Device #1: ID 0x4a MC-1.2 USB 2.0 Manufacturer: MUTEC Model UID: MC-1.2 USB 2.0:29A2:0085 UID: AppleUSBAudioEngine:MUTEC:MC-1.2 USB 2.0:14100000:1,2
