Hello - After a few days of using the latest version, I have to report that I lost all playback on my Kef L50W, streaming Tidal or my library. I cannot use UpNp nor USB wired connection, no sound at all.
Should I uninstall everything and re-install?
Should I remove Audirvana Plus ?
Please let me know, this is annoying.
Thx
Eric
I have the same problem! Why is there no response to this question?
Hello @fifthbusiness, Can you send me a copy of the “Debug Info” while you are trying to listen to your music? You can get it in Audirvana Settings>General>Debug Info
