Hello,
As the title suggests, when I attempt to change the settings of Goodhertz VST3s in Audirvana Studio, the Studio app freezes (‘Not Responding’), and the app needs to be restarted.
The VST3 will run fine without changing the settings, but if I attempt to configure the VST3, I have the issue listed above.
This has been the case since before Studio 2.0, so for quite a while. Trying to change other settings in Audirvana doesn’t seem to help; local vs streamed playback, kernel vs alternatives, UPnP vs attached hardware, raw pcm settings, etc… the problem persists.
Debug info below.
Thanks a bunch,
Paul
Audirvana Studio 2.2.2 (20202)
Windows 10 (19045) with 8GB physical RAM
Connected account of : Paul
Per track: OFF
VST3 plugin #0: C:\Program Files\Common Files\VST3\Ghz CanOpener Studio 3.vst3
ClassID: 5653544353335867687A2063616E6F70
VST3 plugin #1: None
VST3 plugin #2: None
VST3 plugin #3: None
Replay Gain: by album
AUTO: C:\Users\pauls\Desktop\New folder
Library database path: C:\Users\pauls\AppData\Local\Audirvana\Audirvana\AudirvanaDatabase.sqlite
Listening on 2601:248:527f:2a6:4c75:894f:7122:d27a on port 50852
Active method: UPnP
Preferred device: [UPnP] Neutron Music Player [R5] (C5295EEF) Model UID:Neutron Code Limited Neutron Music Player UID:uuid:A7920011-DE27-4411-870D-A6577A931A0A
Selected device:Neutron Music Player [R5] (C5295EEF)
Manufacturer: Neutron Code Limited
Model name: Neutron Music Player
Model UID: Neutron Code Limited Neutron Music Player
UID: uuid:A7920011-DE27-4411-870D-A6577A931A0A
UPnP device at http://192.168.1.120:49559/description.xml
Volume control: Yes
DSD capability: Raw DSD (MSB)
UPnP set capabilities
Maximum PCM frequency set: 384000Hz
Maximum PCM bitdepth set: 32
Maximum DSD rate set: Disabled
Avoid RAW PCM streams: No
http-get::audio/mp3:
http-get::audio/x-mp3:
http-get::audio/mpeg:
http-get::audio/mpeg3:
http-get::audio/x-ms-wma:
http-get::audio/wma:
http-get::audio/wav:
http-get::audio/x-wav:
http-get::audio/ogg:
http-get::audio/x-ogg:
http-get::application/octet-stream:
http-get::audio/flac:
http-get::audio/x-flac:
http-get::audio/musepack:
http-get::audio/x-musepack:
http-get::audio/wavpack:
http-get::audio/x-wavpack:
http-get::audio/ape:
http-get::audio/x-ape:
http-get::audio/mp4:
http-get::audio/m4a:
http-get::audio/x-alac:
http-get::audio/3gpp:
http-get::audio/aiff:
http-get::audio/x-aiff:
http-get::audio/aif:
http-get::audio/x-aif:
http-get::audio/x-caf:
http-get::audio/dsf:
http-get::audio/x-dsf:
http-get::audio/dff:
http-get::audio/x-dff:
http-get::audio/basic:
DLNA 1.5: Yes
Native Gapless playback: Yes
Universal Gapless playback active: Yes
Missing events workaround: No
Can play native DSD: Yes
Volume Control: dB
NrTracks: 1
MediaDuration: 02:15:15
CurrentURI: http://192.168.1.130:49152/audirvana/gaplessAudio_0.wav
CurrentURIMetadata:
dc:titleAudirvana gapless playback</dc:title>
nextURI:
nextURIMetadata:
PlayMedium: NETWORK
RecordMedium: NONE
WriteStatus: NONE
Current transport actions:
Play
<?xml version="1.0"?> 1 0 urn:schemas-upnp-org:device:MediaRenderer:1 Neutron Music Player [R5] (C5295EEF) Neutron Code Limited http://neutroncode.com Neutron Music Player Neutron Music Player 6611 http://neutronmp.com C5295EEF uuid:A7920011-DE27-4411-870D-A6577A931A0A DMR-1.50 image/png 64 64 24 /dmr/media/upnp_icon.png image/png 128 128 24 /dmr/media/upnp_icon_2x.png urn:schemas-upnp-org:service:AVTransport:1 urn:upnp-org:serviceId:AVTransport /dmr/AVTransport/scpd.xml /dmr/AVTransport/control /dmr/AVTransport/event urn:schemas-upnp-org:service:ConnectionManager:1 urn:upnp-org:serviceId:ConnectionManager /dmr/ConnectionManager/scpd.xml /dmr/ConnectionManager/control /dmr/ConnectionManager/event urn:schemas-upnp-org:service:RenderingControl:1 urn:upnp-org:serviceId:RenderingControl /dmr/RenderingControl/scpd.xml /dmr/RenderingControl/control /dmr/RenderingControl/event http://192.168.1.120:49559/Current device RootDevice description:
<?xml version="1.0"?> 1 0 urn:schemas-upnp-org:device:MediaRenderer:1 Neutron Music Player [R5] (C5295EEF) Neutron Code Limited http://neutroncode.com Neutron Music Player Neutron Music Player 6611 http://neutronmp.com C5295EEF uuid:A7920011-DE27-4411-870D-A6577A931A0A DMR-1.50 image/png 64 64 24 /dmr/media/upnp_icon.png image/png 128 128 24 /dmr/media/upnp_icon_2x.png urn:schemas-upnp-org:service:AVTransport:1 urn:upnp-org:serviceId:AVTransport /dmr/AVTransport/scpd.xml /dmr/AVTransport/control /dmr/AVTransport/event urn:schemas-upnp-org:service:ConnectionManager:1 urn:upnp-org:serviceId:ConnectionManager /dmr/ConnectionManager/scpd.xml /dmr/ConnectionManager/control /dmr/ConnectionManager/event urn:schemas-upnp-org:service:RenderingControl:1 urn:upnp-org:serviceId:RenderingControl /dmr/RenderingControl/scpd.xml /dmr/RenderingControl/control /dmr/RenderingControl/event http://192.168.1.120:49559/UPnP devices found : 1
Device #0: Neutron Music Player [R5] (C5295EEF)
Max. memory for audio buffers: 5044MB
Local devices found : 5
Device #0: Hi-Fi Cable Input (VB-Audio Hi-Fi Cable)
Manufacturer: VB-Audio Software
Model UID: VBAudioHFVAIO
UID: \?\SWD#MMDEVAPI#{0.0.0.00000000}.{fc39e9aa-fdbf-4d0e-9433-cf00e56fce8c}#{e6327cad-dcec-4949-ae8a-991e976a79d2}
Model name: Unknown model
Device #1: Speakers (Realtek High Definition Audio)
Manufacturer: Realtek
Model UID: HDAUDIO\FUNC_01&VEN_10EC&DEV_0887&SUBSYS_1458A182&REV_1003
UID: \?\SWD#MMDEVAPI#{0.0.0.00000000}.{f014b020-9940-4ceb-ad75-976e4880e270}#{e6327cad-dcec-4949-ae8a-991e976a79d2}
Device #2: Realtek Digital Output (Realtek High Definition Audio)
UID: \?\SWD#MMDEVAPI#{0.0.0.00000000}.{b3b93099-7241-4637-9ddf-66c3a6c0ac45}#{e6327cad-dcec-4949-ae8a-991e976a79d2}
Device #3: Speakers (Sound Blaster Z SE)
Manufacturer: Creative Technology Ltd.
Model UID: HDAUDIO\FUNC_01&VEN_1102&DEV_0011&SUBSYS_11020028&REV_1009
UID: \?\SWD#MMDEVAPI#{0.0.0.00000000}.{722e1f5e-71e1-4f5f-a5e4-4d053e808fff}#{e6327cad-dcec-4949-ae8a-991e976a79d2}
Device #4: SPDIF-Out (Sound Blaster Z SE)
UID: \?\SWD#MMDEVAPI#{0.0.0.00000000}.{aaa273d7-41ab-4120-b5a7-73372f41b1f5}#{e6327cad-dcec-4949-ae8a-991e976a79d2}
Chromecast devices found : 1
Device #0: Living Room TV
Model name: Chromecast
