It would be really nice if Audirvana could ‘see’ and connect to my DAC even if the DAC is switched on after Audirvana has loaded.
For various reasons I sometimes turn off my DAC and every time I want to use Audirvana again I have to close it and open it again so it ‘sees’ the DAC. A bit tedious.
It would be really nice if Audirvana could sense when its usual DAC has been switched on and just connect to it.
Not a big deal but it would be nice…
Hello @JamesB,
If it’s the DAC you use most of the time then Audirvana should switch to it automatically.
