Connection to networked devices
Hi All,
I’m brand new to Audirvāna (currently in a Studio trial and considering the switch from Roon). I have Studio running on an Intel NUC with Windows 11. USB connection to my DAC is working great, but I can’t send audio to either of my two networked streamers. These are both DLNA capable and are seen as endpoints but the most I get is “initializing audio device”, a skip through all tracks and no actual playback. Any help would be greatly appreciated!
Hi, which streamers do you use? I have had that issue in the dim and distant past but can’t remember what I did to fix it. I sometimes stream to my Cambridge Audio CXN V2 over DNLA which works but I find USB also works so mostly stick to that. (I am on Windows 10.)
I have a RIVA Arena and my LG SJ9 soundbar. Both devices show in my network output options like I said, but WASAPI and ASIO both provide the same result of no audio. The Arena even lights up to indicate it’s getting a signal but nothing…
Have you selected the appropriate device in the network settings? Have you tried disabling any upsampling? I see that the max sample rate for either device is 24/192 and no DSD . You may have to manually select the laptop connection (when using DNLA) on the LG or Arena via their apps (where appropriate) as they may be switched to the TV or some other input. And yes, switch between WASAPI and ASIO.
Hello @tmk1986,
Please remove the line corresponding to your logged-in account to avoid displaying your email address and first name/last name publicly.
Hi, below is the debug info:
Audirvana Studio 1.8.1 (10801)
Windows 11 (22000) with 32GB physical RAM
r8brain with 2x upsampling
AUTO: D:
Library database path: C:\Users\Tyler\AppData\Local\Audirvana\Audirvana\AudirvanaDatabase.sqlite
Listening on 192.168.1.10 on port 52296
Preferred device: Audio Design Experts Inc Riva Arena Model UID:Audio Design Experts Inc Riva Arena UID:uuid:5c1504e4-7eb7-11eb-b90c-2b95426f4274
UPnP device at http://192.168.1.7:38400/description.xml
Riva Arena
Manufacturer: Audio Design Experts Inc
Model Name:
Model UID: Audio Design Experts Inc Riva Arena
UID: uuid:5c1504e4-7eb7-11eb-b90c-2b95426f4274
Volume control: No
Avoid RAW PCM streams: No
http-get:
:audio/L16;rate=44100;channels=2:DLNA.ORG_PN=LPCM
http-get:
:audio/L16;rate=48000;channels=2:DLNA.ORG_PN=LPCM
http-get:
:audio/mp4:DLNA.ORG_PN=AAC_ISO
http-get:
:audio/mp4:DLNA.ORG_PN=AAC_ISO_320
http-get:
:audio/vnd.dlna.adts:DLNA.ORG_PN=AAC_ADTS
http-get:
:audio/flac:*
http-get::audio/x-flac:
http-get::audio/wav:
http-get::audio/x-wav:
http-get::application/ogg:
http-get:
http-get:
:audio/aiff:*
http-get::audio/x-aiff:
DLNA 1.5: Yes
Gapless playback: Yes
Missing events workaround: No
Can play native DSD: No
Volume Control: scalar
NrTracks: 1
MediaDuration: 00:00:00
CurrentURI: http://192.168.1.10:49152/audirvana/audioTest.pcm
CurrentURIMetadata:
dc:titletestTitle</dc:title>
nextURI:
nextURIMetadata:
PlayMedium: NONE
<?xml version="1.0"?> 1 0 SetAVTransportURI InstanceID in A_ARG_TYPE_InstanceID CurrentURI in AVTransportURI CurrentURIMetaData in AVTransportURIMetaData GetMediaInfo InstanceID in A_ARG_TYPE_InstanceID NrTracks out NumberOfTracks MediaDuration out CurrentMediaDuration CurrentURI out AVTransportURI CurrentURIMetaData out AVTransportURIMetaData NextURI out NextAVTransportURI NextURIMetaData out NextAVTransportURIMetaData PlayMedium out PlaybackStorageMedium RecordMedium out RecordStorageMedium WriteStatus out RecordMediumWriteStatus GetTransportInfo InstanceID in A_ARG_TYPE_InstanceID CurrentTransportState out TransportState CurrentTransportStatus out TransportStatus CurrentSpeed out TransportPlaySpeed GetPositionInfo InstanceID in A_ARG_TYPE_InstanceID Track out CurrentTrack TrackDuration out CurrentTrackDuration TrackMetaData out CurrentTrackMetaData TrackURI out CurrentTrackURI RelTime out RelativeTimePosition AbsTime out AbsoluteTimePosition RelCount out RelativeCounterPosition AbsCount out AbsoluteCounterPosition GetDeviceCapabilities InstanceID in A_ARG_TYPE_InstanceID PlayMedia out PossiblePlaybackStorageMedia RecMedia out PossibleRecordStorageMedia RecQualityModes out PossibleRecordQualityModes GetTransportSettings InstanceID in A_ARG_TYPE_InstanceID PlayMode out CurrentPlayMode RecQualityMode out CurrentRecordQualityMode SetPlayMode InstanceID in A_ARG_TYPE_InstanceID NewPlayMode in CurrentPlayMode Stop InstanceID in A_ARG_TYPE_InstanceID Play InstanceID in A_ARG_TYPE_InstanceID Speed in TransportPlaySpeed Pause InstanceID in A_ARG_TYPE_InstanceID Seek InstanceID in A_ARG_TYPE_InstanceID Unit in A_ARG_TYPE_SeekMode Target in A_ARG_TYPE_SeekTarget Next InstanceID in A_ARG_TYPE_InstanceID Previous InstanceID in A_ARG_TYPE_InstanceID GetCurrentTransportActions InstanceID in A_ARG_TYPE_InstanceID Actions out CurrentTransportActions TransportState string STOPPED PAUSED_PLAYBACK PLAYING TRANSITIONING NO_MEDIA_PRESENT TransportStatus string OK ERROR_OCCURRED PlaybackStorageMedium string UNKNOWN CD-DA DVD-VIDEO HDD NETWORK NONE RecordStorageMedium string NOT_IMPLEMENTED PossiblePlaybackStorageMedia string UNKNOWN CD-DA DVD-VIDEO HDD NETWORK PossibleRecordStorageMedia string NOT_IMPLEMENTED CurrentPlayMode string NORMAL SHUFFLE REPEAT_ONE REPEAT_TRACK REPEAT_ALL NORMAL TransportPlaySpeed string 1 RecordMediumWriteStatus string NOT_IMPLEMENTED CurrentRecordQualityMode string NOT_IMPLEMENTED PossibleRecordQualityModes string NOT_IMPLEMENTED NumberOfTracks ui4 0 1 CurrentTrack ui4 0 1 1 CurrentTrackDuration string CurrentMediaDuration string CurrentTrackMetaData string CurrentTrackURI string AVTransportURI string AVTransportURIMetaData string NextAVTransportURI string NextAVTransportURIMetaData string RelativeTimePosition string AbsoluteTimePosition string RelativeCounterPosition i4 AbsoluteCounterPosition i4 CurrentTransportActions string LastChange string A_ARG_TYPE_SeekMode string ABS_COUNT TRACK_NR REL_TIME A_ARG_TYPE_SeekTarget string A_ARG_TYPE_InstanceID ui4
<?xml version="1.0"?> 1 0 DMR-1.50 urn:schemas-upnp-org:device:MediaRenderer:1 Riva Arena Audio Design Experts Inc https://rivaaudio.com RIVA WAND ARENA RIVA ARENA 1.0 https://rivaaudio.com/wand/ 1234567890 uuid:5c1504e4-7eb7-11eb-b90c-2b95426f4274 http://192.168.1.7 urn:schemas-upnp-org:service:RenderingControl:1 urn:upnp-org:serviceId:RenderingControl /RenderingControl.xml /RenderingControl /RenderingControl/eventSub urn:schemas-upnp-org:service:AVTransport:1 urn:upnp-org:serviceId:AVTransport /AVTransport.xml /AVTransport /AVTransport/eventSub urn:schemas-upnp-org:service:ConnectionManager:1 urn:upnp-org:serviceId:ConnectionManager /ConnectionManager.xml /ConnectionManager /ConnectionManager/eventSub http://192.168.1.7:38400
UPnP devices found : 2
Device #0Music Flow SJ9(03:4F) UID: uuid:140479c0-58f3-1cef-84bf-b4e62a7b908e Location: http://192.168.1.18:2870/dmr.xml
Device #1Riva Arena UID: uuid:5c1504e4-7eb7-11eb-b90c-2b95426f4274 Location: http://192.168.1.7:38400/description.xml
Max. memory for audio buffers: 13440MB
Local Audio Engine: ASIO ASIO 1878005520 driver version 32766
Device #0: Pro-Ject Box ASIO Driver Manufacturer: Model UID: Pro-Ject Box ASIO Driver UID: Pro-Ject Box ASIO Driver Model Name: Pro-Ject Box ASIO Driver
@Antoine I have no clue why, but I just opened Audirvana to play to my USB connected DAC, it was set to output to the Riva Arena I was having issues with and I didn’t realize it, and it now works?!
Hello @tmk1986,
Can you go in your device settings in Studio and enable Do not use RAW PCM?
Hi,
Thanks for the support - I have no clue why, but I just opened Audirvana to play to my USB connected DAC, it was set to output to the Riva Arena I was having issues with and I didn’t realize it, and it now works?!
