Hallo bitracer,
here the Debug Info:
Audirvana 3.5.39
VST3 plugin #0: C:\Program Files\Common Files\VST3\Ghz CanOpener Studio 3.vst3
ClassID: 5653544353335867687A2063616E6F70
VST3 plugin #1: C:\Program Files\Common Files\VST3\SatsonCS.vst3
ClassID: 565354436E6573736174736F6E206373
VST3 plugin #2: C:\Program Files\Common Files\VST3\Ghz Midside 3.vst3
ClassID: 5653544D53335867687A206D69647369
VST3 plugin #3: C:\Program Files\Common Files\VST3\Spectre.vst3
ClassID: 56535453705472737065637472650000
Phase = 17
Max allowed volume: 84.5266
Sync list: 0 folders
Library database path: C:\Users\kette\AppData\Local\Audirvana\AudirvanaPlus\AudirvanaPlusDatabaseV2.sqlite
Max. memory for audio buffers: 13654MB
Local Audio Engine:WASAPI
AK380
Model UID:iriver Ltd. AK380
UID:uuid:4d696e69-8398-017c-0102-0018d56483ba
Active Sample Rate: 48kHz
Sample rate switching latency: 1s
Lautsprecher/Kopfhörer (Realtek® Audio) Manufacturer:
Model UID:Lautsprecher/Kopfhörer (Realtek® Audio) UID:\?\SWD#MMDEVAPI#{0.0.0.00000000}.{28715890-75e4-4d44-8950-2e215301c592}#{e6327cad-dcec-4949-ae8a-991e976a79d2}
1 available sample rates up to 48000Hz
Simple stereo device: No
Device #0: Lautsprecher/Kopfhörer (Realtek® Audio) Manufacturer: Model UID: Lautsprecher/Kopfhörer (Realtek® Audio) UID: \?\SWD#MMDEVAPI#{0.0.0.00000000}.{28715890-75e4-4d44-8950-2e215301c592}#{e6327cad-dcec-4949-ae8a-991e976a79d2}
