Constant Audio Dropouts during playback, Win 11, Qobuz
Hi everyone,
I have been using Audirvana Studio for a wee while now and tbh I am getting far too many audio drop outs for my liking.
Is that a common issue with Qobuz on Win 11? I have a very decent system and I have been using it on far more taxing tasks than just audio playback.
All feedback or similar issues would be massively appreciated.
Here is the log book of my system :
Audirvana Studio 3.0.3 (30003)
Running on LENOVO 83DF
Windows 11 (26200) x86_64 with 64GB physical RAM
Connected account of :
Available network interfaces:
Freebox-5151C9 ({***}) is private
Active profile types: all
Private profile:
Firewall: enabled
Inbound: blocked
Outbound: allowed
Notifications: enabled
Public profile:
Firewall: enabled
Inbound: blocked
Outbound: allowed
Third party firewall installed and registered in place of Windows Defender:
Avast Antivirus
REMOTE CONTROL SERVER:
Listening on
192.***
on port 57383
LOADING/DECODING:
Max audio buffer size: 4402MB
Per track: OFF
Convolver: OFF
Internal EQ: ON
Crossfeed: ON
Balance: OFF
in offline mode
PLUGINS: NOT ACTIVE
Volume step size: 1dB
Sync list: 2 folders
AUTO: C:\Users\f_cas\Music\NativeDSD
AUTO: C:\Users\f_cas\Music\Qobuz
Sync folders at startup: YES
Sort and display order: en_US
Library database path: C:\Users\f_cas\AppData\Local\Packages\Audirvana.Audirvana-4118-9684-d80dbb7827cd_q3nymrkmej12j\LocalCache\Local\Audirvana\Audirvana\AudirvanaDatabase.sqlite
Tracks with no MBID: 1003
Font size: large
Language: Langue du système
Favoris
Playlists
Streaming
Radios
Podcasts
Startup view: Bibliothèque locale : Albums
Number of paired remotes: 0
Screen saver disabled: no
Max. memory for audio buffers: 4402MB
WASAPI
Haut-parleurs (HIFIMAN-EF499)
Model UID:USB\VID_2FC6&PID_F043&REV_0201&MI_00
UID:\?\SWD#MMDEVAPI#{0.0.0.00000000}.{23c42fa5-a319-4940-b0ae-6bc58ca56e7e}#{e6327cad-dcec-4949-ae8a-991e976a79d2}
Device: 2ch 16bits Integer, 4 bytes per frame 44.1kHz
Selected device: Haut-parleurs (HIFIMAN-EF499)
Manufacturer: HIFIMAN
Model name: HIFIMAN-EF499
Model UID: USB\VID_2FC6&PID_F043&REV_0201&MI_00
UID: \?\SWD#MMDEVAPI#{0.0.0.00000000}.{23c42fa5-a319-4940-b0ae-6bc58ca56e7e}#{e6327cad-dcec-4949-ae8a-991e976a79d2}
Plays with Audirvāna: No
USB Vendor ID: 0x2fc6
USB Product ID: 0xf043
Max volume alert: Disabled
Simple stereo device: No
Device #0: Haut-parleurs (Realtek(R) Audio)
Manufacturer: Realtek
Model UID: INTELAUDIO\FUNC_01&VEN_10EC&DEV_0257&SUBSYS_17AA3C22&REV_1000
UID: \?\SWD#MMDEVAPI#{0.0.0.00000000}.{a171f837-b85c-4f75-a1b7-94ec2707c5ab}#{e6327cad-dcec-4949-ae8a-991e976a79d2}
Model name: Intel High Definition Audio
Device #1: Haut-parleurs (HIFIMAN-EF499)
Wi-Fi
:folded_hands: thank you!
I use Audirvana on Windows 11, Mac, and Linux, upsampling to DSD512 and streaming to my main system using UPnP. You’re doing no upsampling, maybe some EQ, with a direct connection. I get no dropouts (local or Qobuz), you do while making your system work less hard than I do.
Have you tried other players to see whether the same thing happens with them?
Thanks @Jud , very good point. I am going to experiment with QOBUZ direct (from the desktop App) and will report back once done.
Ok, exactly same issue in QOBUZ desktop app. Basically constant dropouts during the first 20-30 seconds of each track. So the problem definitely lies within QOBUZ or even more upstream…
How do you get Qobuz to your computer (IOW, ISP and router setup)?
Same laptop, connected over WIFI, Fiber optics, Really decent up & donwload speed. Enough for Streaming HD content on the TV
