Another Convolver plugin that does not work in Audirvana
It simply does not show up. In reaper its working as aspected
I have the same problem.
Any solution to this?
No solution until Audirvana will react.
Strange, you can choose and configure in in 3.2.16. In 3.5 it don’t appear in the AU List. I am just testing it in 3.2 with a file from REW
the XT Plugin works fine in A 3.2. No crashes.
