Hi,
I ripped and imported lots of CDs into iTunes.
The music appears in Audirvana correctly, so far synchronisation works fine.
The Cover Art appears in A+ in about 50% of the CDs only !
I cannot see why, no systematics can be identified.
Finally I found the reason and the Solution
When importing CDs into iTunes, the System automatically searches and adds the Cover picture.
In case the System cannot find a picture, you can do it manually.
When doing it manually,
You have to do it by pressing the button ‚Import Coverart‘ (similiar text), Fine for iTunes, Fine for Audirvana.
What i did initially : I insertet the jpg by doing ,copy and Paste‘, Fine for iTunes, but does Not work for Audirvana !
