Hi,
I suddenly have these crackling scratching noices in the background when I listen through my MacBook Pro. Did not have this before. Any idea what it can be? It’s only when I play through the Mac.
Debug below
macOS 11.2.2 with 8192MB RAM
Registered to Janne Alanampa
No plugin active
AUTO: /Volumes/music/FLAC
Library database path: /Users/alanampa/Library/Application Support/Audirvana/AudirvanaPlusDatabaseV2.sqlite
TX-8150
Model UID:ONKYO TX-8150
UID:uuid:2cb09590-dc95-90b9-d09c-9009dcb9d56c
ID 0x31 Built-in Output Manufacturer:Apple Inc.
Model UID:AppleHDA:93 UID:AppleHDAEngineOutput:1B,0,1,1:0
Stream ID 0x32 2 channels starting at 1
4 virtual formats:
12 physical formats
Device #0: ID 0x31 Built-in Output Manufacturer: Apple Inc. Model UID: AppleHDA:93 UID: AppleHDAEngineOutput:1B,0,1,1:0
UPnP devices found : 2
Device #0: ID 0x0 [TV] Samsung Q67 Series (55) UID: uuid:3b427ed2-1e5b-472f-ba49-95e1b1374cc6 Location: http://10.0.1.10:9197/dmr
Device #1: ID 0x0 [AV] Samsung HW Q76R UID: uuid:f9682729-2680-4b4b-9ba9-51f3225eafef Location: http://10.0.1.7:9197/dmr
