I’m using audirvana 3.5 on MacOS 11.5.1 and was pretty happy with it. Installed yesterday Studio 1.6.1.3 as a trial and i liked it. But as soon as i select one of my own created playlists in Qobuz or iTunes local the software completely crashes and i have to restart it again after this self quitting. That’s very annoying and prevents me clearly from purchasing it.
Any similar experiences out there or some tips ? Any help would be greatly appreciated.
Fun fact…when I directly jump into the playlist via the navigator selector box I can at least play single songs. But that‘s all, after playing one song it stops .
That is neither a solution nor a workaround….
Hi Damien, thank you for the info…i have sent it a few minutes ago.
Hopefully you’ll find a solution because at the moment the update from 3.5 is unfortunately no option.
