i have a weird problem
i have updated to the last version , i had the same problem with older version from 3.1.5 to the last
i have tried to import an ntfs hard disk , and audirvana plus freezes , it did happen on itunes
checked this hard disk and it’s perfect , under windows 10/7 muscibee , foobar2000 and audirvana plus for windows ,i have no provlems
the freezing is while is scanning this volume
i have used mp3tag for windows and i have Cyrillic files name and tags
have you notices some problems like that on sierra and high sierra ?
audirvana crashes during the scanning of the volume
I don’t know for log.
You just have to remove files from the folder they are from A+ read them, you don’t have to copy to another place, just put them on same hard disc but in a new folder… if you have like me A to Z folders remove 10 letters and sync, if good put back 3 letters and sync… and on, doesn’t take long to see where the bad file is
