Listening away and then BOOM, music stops playing on headphones and starts playing on PC.
Current version: 1.6.1 (10601)
Bandwidth at 0dB = 99.5%
Phase = 66%
Sync list: 0 folders
Library database path: C:\Users\micha\AppData\Local\Audirvana\Audirvana\AudirvanaDatabase.sqlite
Listening on 192.168.1.10 on port 64418
Max. memory for audio buffers: 3594MB
Vinshine DENAFRIPS USB DAC
Model UID:Vinshine DENAFRIPS USB DAC
Device: 2ch 16bits Integer, 4 bytes per frame 44.1kHz
Speakers (Realtek High Definition Audio)
Manufacturer: Realtek
Model Name: Unknown manufacturer
Model UID: HDAUDIO\FUNC_01&VEN_10EC&DEV_0269&SUBSYS_17AA309D&REV_1002
UID: \?\SWD#MMDEVAPI#{0.0.0.00000000}.{4d87596b-a1ff-4ede-a6de-f7c8c69f90a9}#{e6327cad-dcec-4949-ae8a-991e976a79d2}
Kernel Streaming capable
4 available sample rates up to 192000Hz
Simple stereo device: No
Device #0: Speakers (Realtek High Definition Audio) Manufacturer: Realtek Model UID: HDAUDIO\FUNC_01&VEN_10EC&DEV_0269&SUBSYS_17AA309D&REV_1002 UID: \?\SWD#MMDEVAPI#{0.0.0.00000000}.{4d87596b-a1ff-4ede-a6de-f7c8c69f90a9}#{e6327cad-dcec-4949-ae8a-991e976a79d2} Model Name: Unknown manufacturer
Device #1: Speakers (DENAFRIPS USB DAC) Manufacturer: DENAFRIPS Co. Ltd. Model UID: TUSBAUDIO_ENUM\VID_152A&PID_86EF&REV_0303&KS UID: \?\SWD#MMDEVAPI#{0.0.0.00000000}.{92253601-b8df-45d9-9b4b-f1fdfeb6a3de}#{e6327cad-dcec-4949-ae8a-991e976a79d2} Model Name: Unknown manufacturer
