Yikes, all this time, solid as a rock, today crash city… well not quite, I opened the mini-player, for the first time, and clicked on the start button for audio analysis, and boom, gone instantly…
~If this helps
Audirvana Origin 2.2.2 (20202)
macOS 10.15.7 with 16GB physical RAM
Effects plugins ACTIVE in offline mode with legacy macOS API
AU plugin #0: Music Effect - Waves Abbey Road Studio 3 (s) ()
AU plugin #1: None
AU plugin #2: None
AU plugin #3: None
r8brain to DSD64 with filter type B 7th order
Bandwidth = 95.8342%
Phase minimum phase
Replay Gain: by album
Sync list: 3 folders
AUTO: /Volumes/Music/Music/1.Albums
AUTO: /Volumes/Music/Music/Mixes and Compilations
AUTO: /Volumes/Music/Music/Singles
Library database path: /Users/4bs/Library/Application Support/Audirvana/AudirvanaDatabase.sqlite
Listening on 127.0.0.1 on port 56226
Max. memory for audio buffers: 15360MB
Local Audio Engine: CoreAudio
Exclusive access: ON
Integer mode: ON
iFi (by AMR) iFi (by AMR) HD USB Audio
UID:AppleUSBAudioEngine:iFi (by AMR):iFi (by AMR) HD USB Audio:000:1
Active Sample Rate: 176.4kHz
Selected device:iFi (by AMR) HD USB Audio
Manufacturer: iFi (by AMR)
Model name: iFi (by AMR) HD USB Audio
Model UID: iFi (by AMR) HD USB Audio:20B1:3008
UID: AppleUSBAudioEngine:iFi (by AMR):iFi (by AMR) HD USB Audio:000:1
USB Vendor ID: 0x20b1
USB Product ID: 0x3008
ID 0xd4
Audio buffer frame size : 53 to 4096 frames
MQA Renderer device
Stream ID 0xd5 2 channels starting at 1
24 virtual formats:
32 physical formats
Local devices found : 4
Device #0: ID 0xcc Built-in Output
Model UID: AppleHDA:82
Device #1: ID 0xd4 iFi (by AMR) HD USB Audio
Device #2: ID 0xba Soundflower (2ch)
Manufacturer: ma++ ingalls for Cycling '74
Model UID: com_cycling74_driver_SoundflowerDevice:Soundflower
UID: SoundflowerEngine:0
Model name: ma++ ingalls for Cycling '74 Soundflower (2ch)
Device #3: ID 0x33 Soundflower (64ch)
UID: SoundflowerEngine:1
Model name: ma++ ingalls for Cycling '74 Soundflower (64ch)
