When clicking on the blank sort criteria at bottom of list to add further option, audirvana immediately crashes.
Hello @reddog1,
I just made the check and it crash when you don’t make a sorting choice and you click on the blanck in the selection, am I right?
You are right…
We will fix this in the next update of Audirvana 3.5 for MacOS, thank you for the report.
