Crashes with Mac OS 11.6
Almost always my computer crashes using Mac OS 11.6 (it did not do this with the prior operating systems) when Audirvana 3.5.50 has launched and I try to start the first track of any selected album. After the restart things work fine until the next time I start Audirvana.
Hello @toma,
You mean Audirvana is crashing or MacOS?
Audirvana freezes and then in a couple of seconds the mac totally crashes.
Can you send us a copy of the ā€œDebug Infoā€? You can get it in Audirvana Settings>General>Debug Info
Please remove the line corresponding to your logged-in account to avoid displaying your email address and first name/last name publicly.
Bandwidth at 0dB = 83.394
Filter max length = 9708
Phase = 88
Replay Gain: by album
AUTO: /Volumes/Elements Backup/Music/Lossless Music
Library database path: /Users/tommyalbright/Library/Application Support/Audirvana/AudirvanaPlusDatabaseV2.sqlite
Qobuz: Login failed
Max. memory for audio buffers: 15360MB
HIFI DSD
Model UID:HIFI DSD:20B1:0008
UID:AppleUSBAudioEngine:XMOS :HIFI DSD:14120000:1
Active Sample Rate: 96kHz
Sample rate limitation: 176.4kHz
ID 0x7f HP-DAC1 Manufacturer:SOUNDAVO
Model UID:HP-DAC1:0001:7022 UID:AppleUSBAudioEngine:SOUNDAVO :HP-DAC1:14120000:2,3
32000
Stream ID 0x80 2 channels starting at 1
12 virtual formats:
2 ch Non-mixable linear PCM Interleaved 24 little endian Signed Integer 32kHz
16 physical formats
2 ch Mixable linear PCM Interleaved 24 little endian Signed Integer 32kHz
Local devices found : 9
Device #0: ID 0x86 Manufacturer: Apple Inc. Model UID: AppleGFXHDA:0 UID: AppleGFXHDAEngineOutputDP:f803:0:{0000-0000-00000001}
Device #1: ID 0x7f HP-DAC1 Manufacturer: SOUNDAVO Model UID: HP-DAC1:0001:7022 UID: AppleUSBAudioEngine:SOUNDAVO :HP-DAC1:14120000:2,3
Device #2: ID 0x79 Mac mini Speakers Manufacturer: Apple Inc. Model UID: Speaker UID: BuiltInSpeakerDevice
Device #3: ID 0x33 MJAudioRecorder Manufacturer: MJ Audio Inc. Model UID: MJRecordDeviceModelUID UID: MJRecordDevice
Device #4: ID 0x3c MMAudio Device Manufacturer: MMAudio Device contributors Model UID: MMAudioDeviceModelUID UID: MMAudioDevice
Device #5: ID 0x41 MMAudio Device (UI Sounds) Manufacturer: MMAudio Device contributors Model UID: MMAudioDeviceModelUID_UISounds UID: MMAudioDevice_UISounds
Device #6: ID 0x4d Movavi Sound Grabber Manufacturer: Movavi Software Inc. Model UID: Movavi Sound Grabber 3 (Model UID) UID: Movavi Sound Grabber 3 (Device UID)
Device #7: ID 0x50 Speaker Audio Recorder Manufacturer: Speaker Audio Recorder Model UID: SPRDeviceModelUID UID: SPRDevice
Device #8: ID 0x44 SWB Audio Capture Manufacturer: shinywhitebox ltd Model UID: shinywhitebox ltd UID: SWBAudioCapture:3
UPnP devices found : 1
Device #0: ID 0x0 Sangean WFR 28C 0022615f10ac UID: uuid:3dcc7100-f76c-11dd-87af-0022615f10ac Location: http://10.0.0.50:8080/dd.xml
You can try reducing the buffer to around 2000 mb. That seems to help many folks
Sorry - where is the option for buffer size?
Preferences, Audio,Left side under Loading/Decoding
Do you have the same issue while you have your Mac mini speakers selected?
Actually problem solved - I turned off Integer mode - someone else’s suggestion - and gave Audiovana standard rather than highest priority.
You are welcome.
