Audirvana studio crashes on playback when GEQ Classic DSP plugin is enabled.
debug info:
Audirvana Studio 1.10.2 (11002)
macOS Version 12.1 (Build 21C52) with 16GB physical RAM
Effects plugins ACTIVE in offline mode with legacy macOS API
AU plugin #0: Effect - Waves GEQ Classic (m) ()
AU plugin #1: None
AU plugin #2: None
AU plugin #3: None
SoX with 2x upsampling
Bandwidth at 0dB = 99.5%
Phase = 66%
AUTO: /Volumes/share1/backup/Music
Library database path: /Users/izhavoronkov/Library/Application Support/Audirvana/AudirvanaDatabase.sqlite
Listening on 127.0.0.1 on port 53679
Max. memory for audio buffers: 5082MB
iFi (by AMR) HD USB Audio Output
UID:AppleUSBAudioEngine:iFi (by AMR):iFi (by AMR) HD USB Audio:00000000:1
ID 0x4f Динамики MacBook Pro
Model Name: Apple Inc. Динамики MacBook Pro
Model UID: Speaker
UID: BuiltInSpeakerDevice
Stream ID 0x50 2 channels starting at 1
4 virtual formats:
4 physical formats
Local devices found : 4
Device #0: ID 0x67 DENAFRIPS USB Audio V3.12 Manufacturer: DENAFRIPS Model UID: DENAFRIPS USB Audio V3.12:152A:86EF UID: AppleUSBAudioEngine:DENAFRIPS :DENAFRIPS USB Audio V3.12:14400000:1 Model Name: DENAFRIPS USB Audio V3.12
Device #1: ID 0x5b Внешние наушники Manufacturer: Apple Inc. Model UID: Codec Output UID: BuiltInHeadphoneOutputDevice Model Name: Apple Inc. Внешние наушники
Device #2: ID 0x4f Динамики MacBook Pro Manufacturer: Apple Inc. Model UID: Speaker UID: BuiltInSpeakerDevice Model Name: Apple Inc. Динамики MacBook Pro
Device #3: ID 0x2d Multi-Output Device Manufacturer: Apple Inc. Model UID: ~:AMS2_StackedOutput:0 UID: ~:AMS2_StackedOutput:0 Model Name: Apple Inc. Multi-Output Device
