Thanks @sandsOfArrakis.
Current version: 1.5.7 (10507)
Bandwidth at 0dB = 99.5%
Phase = 66%
Sync list: 2 folders
AUTO: G:\Música
AUTO: C:\Users\Led\Music
Library database path: C:\Users\Led\AppData\Local\Audirvana\Audirvana\AudirvanaDatabase.sqlite
Listening on 2804:5bc:400c:8a0:f41d:59ed:93b6:5e55 on port 51427
Max. memory for audio buffers: 7768MB
Alto-falantes (Realtek High Definition Audio)
Model UID:HDAUDIO\FUNC_01&VEN_10EC&DEV_0899&SUBSYS_80862040&REV_1000
UID:\?\SWD#MMDEVAPI#{0.0.0.00000000}.{a9fb6d84-27c5-498a-8681-de2058af3775}#{e6327cad-dcec-4949-ae8a-991e976a79d2}
Manufacturer: Realtek
Model Name: Unknown manufacturer
Model UID: HDAUDIO\FUNC_01&VEN_10EC&DEV_0899&SUBSYS_80862040&REV_1000
UID: \?\SWD#MMDEVAPI#{0.0.0.00000000}.{a9fb6d84-27c5-498a-8681-de2058af3775}#{e6327cad-dcec-4949-ae8a-991e976a79d2}
Kernel Streaming capable
4 available sample rates up to 192000Hz
Multichannel: 8 channels
Channel bitmap: Oxff, layout:
Channel 2 mapped to 2
Channel 3 mapped to 3
Channel 4 mapped to 4
Channel 5 mapped to 5
Channel 6 mapped to 6
Channel 7 mapped to 7
Number of channels: 8
Simple stereo device: No
Number of active channels: 8, in 1 stream(s)
Channel #6 :Stream 0 channel 6
Channel #7 :Stream 0 channel 7
8 ch Integer PCM 16bit little endian 44.1kHz
8 ch Integer PCM 24bit little endian aligned high in 32bit chunk 44.1kHz
8 ch Integer PCM 16bit little endian 48kHz
8 ch Integer PCM 24bit little endian aligned high in 32bit chunk 48kHz
8 ch Integer PCM 16bit little endian 96kHz
8 ch Integer PCM 24bit little endian aligned high in 32bit chunk 96kHz
8 ch Integer PCM 16bit little endian 192kHz
8 ch Integer PCM 24bit little endian aligned high in 32bit chunk 192kHz
Local devices found : 5
Device #0: Speaker (Digital Video Recorder) Manufacturer: Jaksta Technologies Model UID: jaksta_va UID: \?\SWD#MMDEVAPI#{0.0.0.00000000}.{e2804a8f-e69c-485f-bf0b-a2e545c2f029}#{e6327cad-dcec-4949-ae8a-991e976a79d2} Model Name: Unknown manufacturer
Device #1: T24B350 (NVIDIA High Definition Audio) Manufacturer: NVIDIA Model UID: HDAUDIO\FUNC_01&VEN_10DE&DEV_0041&SUBSYS_38422666&REV_1001 UID: \?\SWD#MMDEVAPI#{0.0.0.00000000}.{5c88ea34-a3cb-4104-aeac-ea3feb698ac9}#{e6327cad-dcec-4949-ae8a-991e976a79d2} Model Name: Unknown manufacturer
Device #2: Realtek Digital Output (Realtek High Definition Audio) Manufacturer: Realtek Model UID: HDAUDIO\FUNC_01&VEN_10EC&DEV_0899&SUBSYS_80862040&REV_1000 UID: \?\SWD#MMDEVAPI#{0.0.0.00000000}.{85eb447b-c60f-4a61-bc80-502d8428faa5}#{e6327cad-dcec-4949-ae8a-991e976a79d2} Model Name: Unknown manufacturer
Device #3: Alto-falantes (Realtek High Definition Audio) Manufacturer: Realtek Model UID: HDAUDIO\FUNC_01&VEN_10EC&DEV_0899&SUBSYS_80862040&REV_1000 UID: \?\SWD#MMDEVAPI#{0.0.0.00000000}.{a9fb6d84-27c5-498a-8681-de2058af3775}#{e6327cad-dcec-4949-ae8a-991e976a79d2} Model Name: Unknown manufacturer
Device #4: Realtek Digital Output(Optical) (Realtek High Definition Audio) Manufacturer: Realtek Model UID: HDAUDIO\FUNC_01&VEN_10EC&DEV_0899&SUBSYS_80862040&REV_1000 UID: \?\SWD#MMDEVAPI#{0.0.0.00000000}.{7c3fb3eb-8f9c-4049-b082-f3fc42e57204}#{e6327cad-dcec-4949-ae8a-991e976a79d2} Model Name: Unknown manufacturer
