Am trialling this currently and it is mostly ok, however the biggest issue for me is it keeps crashing when I click on the artist name within Tidal.
On a iMac (Catalina)
Click on Tidal - Rising
Click on an Album - click on the artists name - and then I often get the app crashing and closing. Seems to be hit and miss as to whether it works or not.
Is this a known issue?
It is a shame, despite a few other nuances, it is rally good, but the crashing is causing me to hesitate in purchasing.
Debug Info:
macOS 10.15.6 with 65536MB RAM
AUTO: /Volumes/Multimedia/Music/Lossless
Library database path: /Users/jonrayner/Library/Application Support/Audirvana/AudirvanaPlusDatabaseV2.sqlite
Max. memory for audio buffers: 62464MB
iFi (by AMR) HD USB Audio Output
UID:AppleUSBAudioEngine:iFi (by AMR):iFi (by AMR) HD USB Audio:00000000:1
ID 0x29 iFi (by AMR) HD USB Audio Output Manufacturer:iFi (by AMR)
Model UID:iFi (by AMR) HD USB Audio:20B1:3008 UID:AppleUSBAudioEngine:iFi (by AMR):iFi (by AMR) HD USB Audio:00000000:1
MQA Renderer device
16 virtual formats:
16 physical formats
Device #0: ID 0x32 Built-in Output Manufacturer: Apple Inc. Model UID: AppleHDA:16 UID: AppleHDAEngineOutput:1F,3,0,1,1:0
Device #1: ID 0x29 iFi (by AMR) HD USB Audio Output Manufacturer: iFi (by AMR) Model UID: iFi (by AMR) HD USB Audio:20B1:3008 UID: AppleUSBAudioEngine:iFi (by AMR):iFi (by AMR) HD USB Audio:00000000:1
UPnP devices found : 2
Device #0: ID 0x0 PANASONIC TV UID: uuid:13ccf248-9910-1ab8-952a-7054b4376ec8 Location: http://192.168.1.214:2870/dmr.xml
Device #1: ID 0x0 XBOXONE UID: uuid:0274dc2b-33f4-4a9b-9d06-46ff618b169c Location: http://192.168.1.251:2869/upnphost/udhisapi.dll?content=uuid:0274dc2b-33f4-4a9b-9d06-46ff618b169c
