Hello @jsalino, which version of Audirvana are you using?
The most recent Mac version. Always up to date. Thank you
Note: By clicking on the Debug Info Audirvana button automatically copies all its content, all you have to do is paste it in response to this message.
Note same crashing happens with different audio interfaces. Not every time.
Audirvana Mac Version 3.5.33 (3563)
macOS 10.14.6 with 32768MB RAM
Registered to J*** S***
AUTO: /Volumes/FLAC/FLAC Library
Library database path: /Users/jodysalino/Library/Application Support/Audirvana/AudirvanaPlusDatabaseV2.sqlite
Exclusive access: Disabled
Sonarworks Systemwide
Model UID:com_sonarworks_driver_SonarworksDevice:Sonarworks
UID:SonarworksEngine:0
ID 0x76 Sonarworks Systemwide Manufacturer:SIA Sonarworks
Model UID:com_sonarworks_driver_SonarworksDevice:Sonarworks UID:SonarworksEngine:0
Stream ID 0x77 2 channels starting at 1
6 virtual formats:
6 physical formats
2 ch Mixable linear PCM Interleaved 32 big endian Signed Integer 192kHz
2 ch Mixable linear PCM Interleaved 32 big endian Signed Integer 176.4kHz
2 ch Mixable linear PCM Interleaved 32 big endian Signed Integer 96kHz
2 ch Mixable linear PCM Interleaved 32 big endian Signed Integer 88.2kHz
2 ch Mixable linear PCM Interleaved 32 big endian Signed Integer 48kHz
2 ch Mixable linear PCM Interleaved 32 big endian Signed Integer 44.1kHz
Local devices found : 8
Device #0: ID 0x6b Built-in Output Manufacturer: Apple Inc. Model UID: AppleHDA:66 UID: AppleHDAEngineOutput:1B,0,1,3:0
Device #1: ID 0x62 Built-in Line Output Manufacturer: Apple Inc. Model UID: AppleHDA:66 UID: AppleHDAEngineOutput:1B,0,1,4:1
Device #2: ID 0x5e Built-in Digital Output Manufacturer: Apple Inc. Model UID: AppleHDA:66 UID: AppleHDAEngineOutput:1B,0,1,5:2
Device #3: ID 0x2f Duet USB Manufacturer: Apogee Model UID: AppleUSBAudioDevice:Duet USB UID: AppleUSBAudioEngine:Apogee:Duet USB:400000:1,2
Device #4: ID 0x2a SoundSticks Manufacturer: harman/kardon Model UID: SoundSticks:05FC:7849 UID: AppleUSBAudioEngine:harman/kardon:SoundSticks:1a200000:1
Device #5: ID 0x42 BlackHole Manufacturer: Existential Audio Inc. Model UID: BlackHole_ModelUID UID: BlackHole_UID
Device #6: ID 0x76 Sonarworks Systemwide Manufacturer: SIA Sonarworks Model UID: com_sonarworks_driver_SonarworksDevice:Sonarworks UID: SonarworksEngine:0
Device #7: ID 0x4b AirParrot Manufacturer: squirrels Model UID: com_squirrels_driver_AudioDevice:AirParrotSpeakers UID: com_squirrels_driver_AudioEngine:0
It even happens with the built-in output of your Mac?
No idea. The point of this software is to use quality converters. I don’t have that output connected to anything.
Since you have crash happening we need to identify what is the source of the issue, I can be the device you selected, this is why i want to know if you have crash with other audio device.
I tried it with the built in output and it crashes intermittently on closing the program with uncaught exception errors.
Hello @jsalino, since you also have crash with built in output, can you send us the crash log you can find in the console app of your Mac to support@audirvana.com ?
