hi everyone, does anyone have this problem?, when i pause a or when i move to another song there is this sound like a creak or chirp in my speakers, i noticed that this happen just in audirvana because if a i use the app of tidal there is no sound at all when i pause the song, do you know what can possibly be? thank you!
its already deactivated, i just checked on tidal app via PC and the same is happening (i had checked on my phone) so i think is something related to PCs (i have two PC and is the same)
It could be your DAC. Can you paste the debug info here?
i have two dac, a dragonfly red and a Topping d50s, same thing with both of them
Audirvana 3.5.38
Sync list: 0 folders
Library database path: C:\Users\sdroguet\AppData\Local\Audirvana\AudirvanaPlus\AudirvanaPlusDatabaseV2.sqlite
Max. memory for audio buffers: 1152MB
Local Audio Engine:WASAPI
Speakers (AudioQuest DragonFly Red v1.0)
Model UID:Speakers (AudioQuest DragonFly Red v1.0)
UID:\?\SWD#MMDEVAPI#{0.0.0.00000000}.{850f775b-9886-4196-a080-62eaa75de8d2}#{e6327cad-dcec-4949-ae8a-991e976a79d2}
Speakers (AudioQuest DragonFly Red v1.0) Manufacturer:
Model UID:Speakers (AudioQuest DragonFly Red v1.0) UID:\?\SWD#MMDEVAPI#{0.0.0.00000000}.{850f775b-9886-4196-a080-62eaa75de8d2}#{e6327cad-dcec-4949-ae8a-991e976a79d2}
MQA Renderer device
Simple stereo device: No
Local devices found : 3
Device #0: Sonido Intel® para pantallas - HDMI 1 (2- Intel® Display Audio) Manufacturer: Model UID: Sonido Intel® para pantallas - HDMI 1 (2- Intel® Display Audio) UID: \?\SWD#MMDEVAPI#{0.0.0.00000000}.{33eba82a-e1ac-4899-a168-2c0da96f9ca9}#{e6327cad-dcec-4949-ae8a-991e976a79d2}
Device #1: Speakers (AudioQuest DragonFly Red v1.0) Manufacturer: Model UID: Speakers (AudioQuest DragonFly Red v1.0) UID: \?\SWD#MMDEVAPI#{0.0.0.00000000}.{850f775b-9886-4196-a080-62eaa75de8d2}#{e6327cad-dcec-4949-ae8a-991e976a79d2}
Device #2: Speakers (Conexant ISST Audio) Manufacturer: Model UID: Speakers (Conexant ISST Audio) UID: \?\SWD#MMDEVAPI#{0.0.0.00000000}.{b8be43dd-5cd5-4043-b5b2-136785e70108}#{e6327cad-dcec-4949-ae8a-991e976a79d2}
Hello @sebas_dro,
When you are using your DF or D50s, are you using the same USB connector on your computer?
yes i have used the same usb port, actually i have tried in two different computers with my speakers and earphones and the sound is there
Are the DACs connected via USB hub?
no, they are conncected directly to the usb connector of the computer
Have you tried to connect your device to a different USB port of your computer?
