Hi, I wanted to know if it’s possible to create playlists from subfolders. As you can see in the screenshot, my music folder contains subfolder classified by the kind of music & I want every subfolder to be a playlist in audirvana (also to update itself when I add a song to a folder).
If it’s possible, how to do so ? thank you
hi,
as far as I know you can build an intelligent playlist based on creteria “location”.
I have a subfolder named MQA and use such a playlist to show only files that have “MQA” in the filepath.
Works for me.
cenar
Same problem and the location thing doesn’t work for me at all. I logged in yesterday to see if anyone had a solution, Woke up this am and bingo a solution. Download musicbrainz picard, drop the folder in, let the app fill in all the blanks, Select all and rename the album, and Album Artists as Various or so, Save. Go back to Audirvana and select album. Done took me a hour to do 2000 Flac files 12 Folders as Various Playlists. Looks good all the tags are done, covers etc. Maybe a plugin can be written in future.
