I use goodherz can opener plug in for crossfeed running Audirvana Studio on my MacbookPro which is connected to my DAC by USB.
I works well.
Recently I have changed the set up: Studio streams to my DAP, an AK300S. The DAP is connected to my DAC by USB.
Now the Goodherz plug in does not function although Audirvana shows it as running as normal. The signal being streamed to the DAP is not affected by the plugin.
Any idea why?
Hi @Sjcrowther,
Audirvana Studio 2.8.3.0 (20803)
macOS 14.6.1 with 16GB physical RAM
Connected account of : Stewart Crowther
Per track: OFF
AU plugin #0: Effect - Goodhertz Ghz CanOpener Studio 3 ()
AU plugin #1: None
AU plugin #2: None
AU plugin #3: None
AUTO: /Users/stewartcrowther/Music
Library database path: /Users/stewartcrowther/Library/Application Support/Audirvana/AudirvanaDatabase.sqlite
Tracks with no MBID: 0
Listening on 127.0.0.1 on port 49152
Font size: regular
My Music
Streaming
Radios
Podcasts
Use Apple Remote: no
Number of paired remotes: 2
Screen saver disabled: yes
Active method: UPnP
Preferred device: [UPnP] SE300 Model UID:IRIVER Ltd. AK Connect Renderer UID:uuid:4d696e69-8398-8d5d-0102-0018d570866f
Currently playing to UPnP device at 32 bits 44.1kHz
Selected device:SE300
Manufacturer: IRIVER Ltd.
Model name: AK Connect Renderer
Model UID: IRIVER Ltd. AK Connect Renderer
UID: uuid:4d696e69-8398-8d5d-0102-0018d570866f
UPnP device at http://192.168.1.15:5500/upnp/dev/4d696e69-8398-8d5d-0102-0018d570866f/desc
ID 0x0
Volume control: Yes
Max volume alert: Disabled
Raw DSD (msb)
UPnP set capabilities
Maximum PCM bitdepth set: 32
Maximum DSD rate set: DSD256
Avoid RAW PCM streams: No
Unwanted playback stop workaround: Yes
http-get::audio/mpeg:DLNA.ORG_PN=MP3;DLNA.ORG_OP=01;DLNA.ORG_FLAGS=40000000000000000000000000000000
http-get::audio/mp4:DLNA.ORG_PN=M4A;DLNA.ORG_OP=01;DLNA.ORG_FLAGS=40000000000000000000000000000000
http-get::audio/x-wav:DLNA.ORG_PN=WAV;DLNA.ORG_OP=01;DLNA.ORG_FLAGS=40000000000000000000000000000000
http-get::audio/x-ms-wma:DLNA.ORG_PN=WMA;DLNA.ORG_OP=01;DLNA.ORG_FLAGS=40000000000000000000000000000000
http-get::audio/ogg:DLNA.ORG_PN=OGG;DLNA.ORG_OP=01;DLNA.ORG_FLAGS=40000000000000000000000000000000
http-get::audio/aac:DLNA.ORG_PN=AAC;DLNA.ORG_OP=01;DLNA.ORG_FLAGS=40000000000000000000000000000000
http-get::audio/x-ape:DLNA.ORG_PN=APE;DLNA.ORG_OP=01;DLNA.ORG_FLAGS=40000000000000000000000000000000
http-get::audio/dsf:DLNA.ORG_PN=DSF;DLNA.ORG_OP=01;DLNA.ORG_FLAGS=40000000000000000000000000000000
http-get::audio/dff:DLNA.ORG_PN=DSD;DLNA.ORG_OP=01;DLNA.ORG_FLAGS=40000000000000000000000000000000
http-get::audio/aiff:DLNA.ORG_PN=AIFF;DLNA.ORG_OP=01;DLNA.ORG_FLAGS=40000000000000000000000000000000
http-get:*:audio/flac:DLNA.ORG_PN=FLAC;DLNA.ORG_OP=01;DLNA.ORG_FLAGS=40000000000000000000000000000000
DLNA 1.5: No
Native Gapless playback: Yes
Can play native DSD: Yes
Volume Control: dB (0dB to 0dB)
33 virtual formats:
2 ch Non-mixable linear PCM Interleaved 32 little endian Signed Integer 44.1kHz finite length
2 ch Non-mixable linear PCM Interleaved 32 little endian Signed Integer 88.2kHz finite length
2 ch Non-mixable linear PCM Interleaved 32 little endian Signed Integer 176.4kHz finite length
2 ch Non-mixable linear PCM Interleaved 32 little endian Signed Integer 352.8kHz finite length
2 ch Non-mixable linear PCM Interleaved 16 little endian Signed Integer 705.6kHz finite length
2 ch Non-mixable linear PCM Interleaved 24 little endian Signed Integer 705.6kHz finite length
2 ch Non-mixable linear PCM Interleaved 32 little endian Signed Integer 705.6kHz finite length
2 ch Non-mixable linear PCM Interleaved 32 little endian Signed Integer 48kHz finite length
2 ch Non-mixable linear PCM Interleaved 32 little endian Signed Integer 96kHz finite length
2 ch Non-mixable linear PCM Interleaved 32 little endian Signed Integer 192kHz finite length
2 ch Non-mixable linear PCM Interleaved 32 little endian Signed Integer 384kHz finite length
2 ch Non-mixable linear PCM Interleaved 16 little endian Signed Integer 768kHz finite length
2 ch Non-mixable linear PCM Interleaved 24 little endian Signed Integer 768kHz finite length
2 ch Non-mixable linear PCM Interleaved 32 little endian Signed Integer 768kHz finite length
2 ch Non-mixable linear PCM Interleaved 8 little endian Signed Integer 11289.6kHz finite length
0 physical formats
NrTracks: 1
MediaDuration: 00:13:51
CurrentURI: http://192.168.1.250:49153/audirvana/audio_f_35.wav
CurrentURIMetadata: dc:titleLiszt: Harmonies Poétiques Et Religieuses, S 173/4 - Pensée Des Morts</dc:title>dc:creatorSteven Osborne</dc:creator>upnp:classobject.item.audioItem.musicTrack</upnp:class>upnp:artistSteven Osborne</upnp:artist><upnp:author role=“Composer”>Liszt</upnp:author>upnp:genreClassical</upnp:genre>upnp:albumArtURIhttp://192.168.1.250:49153/audirvana/artwork_1_35.jpg</upnp:albumArtURI>upnp:albumLiszt: Harmonies Poétiques Et Religieuses</upnp:album>upnp:originalTrackNumber4</upnp:originalTrackNumber>http://192.168.1.250:49153/audirvana/audio_f_35.wav
nextURI: http://192.168.1.250:49153/audirvana/audio_f_37.wav
nextURIMetadata: dc:titleLiszt: Harmonies Poétiques Et Religieuses, S 173/5 - Pater Noster</dc:title>dc:creatorSteven Osborne</dc:creator>upnp:classobject.item.audioItem.musicTrack</upnp:class>upnp:artistSteven Osborne</upnp:artist><upnp:author role=“Composer”>Liszt</upnp:author>upnp:genreClassical</upnp:genre>upnp:albumArtURIhttp://192.168.1.250:49153/audirvana/artwork_0_37.jpg</upnp:albumArtURI>upnp:albumLiszt: Harmonies Poétiques Et Religieuses</upnp:album>upnp:originalTrackNumber5</upnp:originalTrackNumber>http://192.168.1.250:49153/audirvana/audio_f_37.wav
PlayMedium: NETWORK
Current transport actions:
Stop,Pause,Seek
<?xml version="1.0"?> 1 0 urn:schemas-upnp-org:device:MediaRenderer:1 SE300 IRIVER Ltd. http://www.iriver.com DMR on Astell&Kern AK Connect Renderer 1.0 http://www.iriver.com 0000-0000-0000-0000 uuid:4d696e69-8398-8d5d-0102-0018d570866f 000000000000 image/png 48 48 8 /upnp/dev/4d696e69-8398-8d5d-0102-0018d570866f/icon_48 urn:schemas-upnp-org:service:ConnectionManager:1 urn:upnp-org:serviceId:ConnectionManager /upnp/dev/4d696e69-8398-8d5d-0102-0018d570866f/svc/upnp-org/ConnectionManager/desc /upnp/dev/4d696e69-8398-8d5d-0102-0018d570866f/svc/upnp-org/ConnectionManager/action /upnp/dev/4d696e69-8398-8d5d-0102-0018d570866f/svc/upnp-org/ConnectionManager/event urn:schemas-upnp-org:service:AVTransport:1 urn:upnp-org:serviceId:AVTransport /upnp/dev/4d696e69-8398-8d5d-0102-0018d570866f/svc/upnp-org/AVTransport/desc /upnp/dev/4d696e69-8398-8d5d-0102-0018d570866f/svc/upnp-org/AVTransport/action /upnp/dev/4d696e69-8398-8d5d-0102-0018d570866f/svc/upnp-org/AVTransport/event urn:schemas-upnp-org:service:RenderingControl:1 urn:upnp-org:serviceId:RenderingControl /upnp/dev/4d696e69-8398-8d5d-0102-0018d570866f/svc/upnp-org/RenderingControl/desc /upnp/dev/4d696e69-8398-8d5d-0102-0018d570866f/svc/upnp-org/RenderingControl/action /upnp/dev/4d696e69-8398-8d5d-0102-0018d570866f/svc/upnp-org/RenderingControl/eventCurrent device RootDevice description:
<?xml version="1.0"?> 1 0 urn:schemas-upnp-org:device:MediaRenderer:1 SE300 IRIVER Ltd. http://www.iriver.com DMR on Astell&Kern AK Connect Renderer 1.0 http://www.iriver.com 0000-0000-0000-0000 uuid:4d696e69-8398-8d5d-0102-0018d570866f 000000000000 image/png 48 48 8 /upnp/dev/4d696e69-8398-8d5d-0102-0018d570866f/icon_48 urn:schemas-upnp-org:service:ConnectionManager:1 urn:upnp-org:serviceId:ConnectionManager /upnp/dev/4d696e69-8398-8d5d-0102-0018d570866f/svc/upnp-org/ConnectionManager/desc /upnp/dev/4d696e69-8398-8d5d-0102-0018d570866f/svc/upnp-org/ConnectionManager/action /upnp/dev/4d696e69-8398-8d5d-0102-0018d570866f/svc/upnp-org/ConnectionManager/event urn:schemas-upnp-org:service:AVTransport:1 urn:upnp-org:serviceId:AVTransport /upnp/dev/4d696e69-8398-8d5d-0102-0018d570866f/svc/upnp-org/AVTransport/desc /upnp/dev/4d696e69-8398-8d5d-0102-0018d570866f/svc/upnp-org/AVTransport/action /upnp/dev/4d696e69-8398-8d5d-0102-0018d570866f/svc/upnp-org/AVTransport/event urn:schemas-upnp-org:service:RenderingControl:1 urn:upnp-org:serviceId:RenderingControl /upnp/dev/4d696e69-8398-8d5d-0102-0018d570866f/svc/upnp-org/RenderingControl/desc /upnp/dev/4d696e69-8398-8d5d-0102-0018d570866f/svc/upnp-org/RenderingControl/action /upnp/dev/4d696e69-8398-8d5d-0102-0018d570866f/svc/upnp-org/RenderingControl/eventUPnP devices found : 1
Device #0: ID 0x0 : SE300
Location: http://192.168.1.15:5500/upnp/dev/4d696e69-8398-8d5d-0102-0018d570866f/desc
Max. memory for audio buffers: 15360MB
Local Audio Engine: CoreAudio
Device #0: ID 0x48 MacBook Pro Speakers
Model UID: Speaker
UID: BuiltInSpeakerDevice
Chromecast devices found : 1
Device #0: Living Room TV
Model name: Chromecast
Can you please check your device is in USB mode? It seems it is using UPNP?
To complicate matters the DAP is not connected to the DAC directly: the USB cable from the DAP goes to a Denafrips Gaia DDD and from there by i2s to the DAC. I don’t think that makes a difference? My DAC is a Denafrips Terminator.
Neither the DDD nor the DAC are capable of streaming. They need a cable connection.
While playing music if I disconnect the USB cable from the DAP the music stops.
The MacBook streams to the DAP by UPnP.
In such a case, you will need to deactivate real-time option in the plugin settings other wise the plugin will not work.
Thank you. That seems to work.
Another question:
Is there anyway to make UPnP play gapless?
I have.
“fix for devices with unwanted playback stops” makes no difference for gapless.
Universal gapless playback mode makes the tracks gapless BUT the stream stops randomly mid track.
And with the three activated?
It is the same with all three activated or with the second deactivated.
The stream stops mid-track and the padlock icon at bottom right opens.
Can you go into the Audirvāna settings and in the My Account section? You will see a ‘Start Log Session’ button; click on it and reproduce your issue.
After you reproduce it, click 'Stop Log Session’ and then close Audirvāna, then post the end of the audirvana_studio.log file you can find by clicking the 'Open Log Folder’ button.
I can but the log will be long. It could be a few minutes before the player stops.
Do you want the log with all 3 gapless switches on?
Yes, please, only post the last ten lines of it ![]()
Lower your playback pre-load memory allocation to 4GB… you are allocating nearly 100% of your System RAM for pre-load buffer.
024-08-29 22:02:24.465 [debug]: Network gapless buffer 0 starting at 69859104 length updated to 40449696 bytes
2024-08-29 22:02:24.465 [debug]: Network gapless other buffer 1 start updated to 110308800 bytes
2024-08-29 22:02:24.465 [debug]: Network gapless buffer 0 starting at 69859104 length NOT updated: 40449696 bytes
2024-08-29 22:02:25.666 [debug]: Network gapless received play time 202:53 for buffer 0 changing
2024-08-29 22:02:25.682 [debug]: Network gapless buffer 1 starting at 110308800 length updated to 39690000 bytes
2024-08-29 22:02:25.682 [debug]: Network gapless preloadNextChunk buffer 0 gapless at start pos 149998800 length 30176160 bytes
2024-08-29 22:02:25.683 [debug]: Network gapless buffer 1 starting at 110308800 length updated to 40023984 bytes
2024-08-29 22:02:25.683 [debug]: Network gapless other buffer 0 start updated to 150332784 bytes
2024-08-29 22:02:25.683 [debug]: Network gapless buffer 1 starting at 110308800 length NOT updated: 40023984 bytes
2024-08-29 22:03:04.806 [error]: UPnP: Error -302 unsubscribing from AVTransport events when stopping
2024-08-29 22:03:04.828 [error]: UPnP Error 402 setting NextAVTransportURI to on instance 0
2024-08-29 22:03:04.829 [warning]: UPnP Error resetting NextAVTransportURI when stopping
2024-08-29 22:03:04.858 [error]: UPnP Error 402 setting AVTransportURI to on instance 0
2024-08-29 22:03:04.858 [warning]: UPnP Error resetting AVTransportURI when stopping
Thanks I’ll do that.
Does not seem to make any difference to the issue of gapless.
Any progress?
Hi @Sjcrowther,
Can you please send me the whole log file by email at [email protected]?
