CueSheet format
Hi.
I have a 5.1 surround file in CueSheet format (though the file’s name is a .wav). VLC plays it, but not Audirvana; I get white noise in stereo. Anything I can do?
Hello @jpcote,
Hi Damien,
There you go (down below).
All audio software that I have see the WAV file as a stereo one (therefore playing white noise), and so is Audirvana. None of those apps seems to see and read or use the .cue file. VLC and such video players do.
I am not familiar with this format. It appears to be a WAVE file that is actually encoded, with the decode info in the .cue file?
I wonder how I could de-interleave the 5.1 tracks and/or convert this to PCM (?)… Or is Audirvana supposed to be able to associate —and decode— the .cue file?
JPC
Debug Info :
Audirvana Mac Version 3.5.40 (3570)
macOS 10.14.6 with 16384MB RAM
Licence enregistrée pour Jean-Pierre Côté
AUTO: /Users/parentscote/Music
Library database path: /Users/parentscote/Library/Application Support/Audirvana/AudirvanaPlusDatabaseV2.sqlite
Direct Mode audio path, buffer I/O frame size: 2048
Exclusive access: Disabled
MHLink Audio [00075900b762]
Model UID:ULN-8
UID:com.mhlabs.mhlink.00075900b762
Device: 16ch Mixable linear PCM Interleaved 32bits little endian Signed Float, 64 bytes per frame 192kHz
Active Sample Rate: 192kHz
Sample rate switching latency: 0.5s
ID 0x3e MHLink Audio [00075900b762] Manufacturer:Metric Halo
Model UID:ULN-8 UID:com.mhlabs.mhlink.00075900b762
Audio buffer frame size : 58 to 3072 frames
Current I/O buffer frame size : 2048
Multichannel: 16 channels
Channel bitmap: Ox3f, layout:
Channel 2 mapped to 2
Channel 3 mapped to 3
Channel 4 mapped to 4
Channel 5 mapped to 5
Channel 6 unused
Channel 7 unused
Channel 8 unused
Channel 9 unused
Channel 10 unused
Channel 11 unused
Channel 12 unused
Channel 13 unused
Channel 14 unused
Channel 15 unused
Number of channels: 16
Simple stereo device: No
Number of active channels: 16, in 1 stream(s)
Channel #6 :Stream 0 channel 6
Channel #7 :Stream 0 channel 7
Channel #8 :Stream 0 channel 8
Channel #9 :Stream 0 channel 9
Channel #10 :Stream 0 channel 10
Channel #11 :Stream 0 channel 11
Channel #12 :Stream 0 channel 12
Channel #13 :Stream 0 channel 13
Channel #14 :Stream 0 channel 14
Channel #15 :Stream 0 channel 15
Stream ID 0x3f 16 channels starting at 1
6 virtual formats:
16 ch Mixable linear PCM Interleaved 32 little endian Signed Float 192kHz
16 ch Mixable linear PCM Interleaved 32 little endian Signed Float 176.4kHz
16 ch Mixable linear PCM Interleaved 32 little endian Signed Float 96kHz
16 ch Mixable linear PCM Interleaved 32 little endian Signed Float 88.2kHz
16 ch Mixable linear PCM Interleaved 32 little endian Signed Float 48kHz
16 ch Mixable linear PCM Interleaved 32 little endian Signed Float 44.1kHz
6 physical formats
16 ch Mixable linear PCM Interleaved 32 big endian Signed Integer 192kHz
16 ch Mixable linear PCM Interleaved 32 big endian Signed Integer 176.4kHz
16 ch Mixable linear PCM Interleaved 32 big endian Signed Integer 96kHz
16 ch Mixable linear PCM Interleaved 32 big endian Signed Integer 88.2kHz
16 ch Mixable linear PCM Interleaved 32 big endian Signed Integer 48kHz
16 ch Mixable linear PCM Interleaved 32 big endian Signed Integer 44.1kHz
Local devices found : 4
Device #0: ID 0x34 Sortie intégrée Manufacturer: Apple Inc. Model UID: AppleHDA:88 UID: AppleHDAEngineOutput:1B,0,1,2:0
Device #1: ID 0x44 HDMI Manufacturer: Apple Inc. Model UID: AppleHDA:88 UID: AppleHDAEngineOutputDP:1B,3,1,0:0:{2D4C-0D37-30503255}
Device #2: ID 0x48 HDMI Manufacturer: Apple Inc. Model UID: AppleHDA:88 UID: AppleHDAEngineOutputDP:1B,3,1,2:1:{A934-A0D8-01010101}
Device #3: ID 0x3e MHLink Audio [00075900b762] Manufacturer: Metric Halo Model UID: ULN-8 UID: com.mhlabs.mhlink.00075900b762
Can you send us your file at [email protected]?
Hello @jpcote,
Your file is encoded in DTS, we do not support this lossy format thus VLC have it embedded but they do not pay for it. Playing this kind of DTS 5.1 file need to have the DTS decoder in the program.
Ok thanks.
Can Audirvana play such files straight to my surround decoder via a digital connection (TOSLINK or coax)?
Replying to myself. I tried it, and yes, it does work (to send the DTS encoded audio to the surround decoder through digital coax, using Audirvana as the player). The downside is that upsampling is, then, not possible (for obvious reasons). Is there anyway to easily set Audirvana to perform upsampling (or not to) only under certain conditions? Or a quicker/easier way to do it than getting to the audio interface settings?
This is actually not possible but we are thinking about it for a future update of Audirvana.
