I am running Audirvana Mac Version 3.5.38 (3568)
macOS 10.15.5 with 16384MB RAM
This does not happen all the time but it has happened several times. When I sync Audirvana to iTunes using file system, it all works properly. Here is my setup:
Sync list: 3 folders
AUTO: /Users/msacks3/Music/Mikey’s Playlists
AUTO: /Volumes/OWC HD/iTunes/iTunes Media/Music
AUTO: /Volumes/OWC HD/iTunes/iTunes Music
Library database path: /Users/msacks3/Library/Application Support/Audirvana/AudirvanaPlusDatabaseV2.sqlite
When the bug occurs it expresses itself like this, and only on the 2nd track on the album. Say the duration of the track in iTunes is 3:50. In Audirvana it also shows as 3:50. But when you start to play the track, Audirvana drops 6 seconds from the duration. The result is that the last 6 seconds of the track are not played. If I dupe the file and place it at the end of the album (say track 20), it plays properly. But as long a it is track 2, Audirvana drops 6 seconds from the track.
Weird.
