Dear Audirvana team
I recently purchased Audirva + Cambridge CXNv2.
However, i unabled to play music on Audirvana via Qobuz streaming. Indeed, everytime i click the play button, im getting the message “Loading first track…” and it never disappears…
It’s pretty much weird as sometimes it works… and the next day it does not and i’m stuck
I have disabled firewall, upsampling, reduced memory allocated to 2gb, nothing changes.
Please help as it makes me crazy, thanks in advance sur support.
I’m using windows 10 with 32gb ram.
See below the debug info
Audirvana 3.5.45
Sync list: 0 folders
Library database path: C:\Users\guill\AppData\Local\Audirvana\AudirvanaPlus\AudirvanaPlusDatabaseV2.sqlite
Preferred device: CXNv2 GCS Model UID:Cambridge Audio CXNv2 GCS UID:uuid:36d41bac-4a16-485c-9959-ffbfc9d27778
UPnP device at http://192.168.0.16:8050/36d41bac-4a16-485c-9959-ffbfc9d27778/description.xml
CXNv2 GCS Manufacturer:Cambridge Audio
Volume control: No
DSD capability: Raw DSD (MSB)
http-get::audio/x-ms-wma:DLNA.ORG_PN=WMALSL
http-get::audio/mpeg:
http-get::audio/m4a:
http-get::audio/x-m4a:
http-get::audio/aac:
http-get::audio/wave:
http-get::audio/wav:
http-get::audio/x-wav:
http-get::audio/aiff:
http-get::audio/x-aiff:
http-get::audio/flac:
http-get::audio/x-flac:
http-get::audio/ation/ogg:
http-get::audio/ogg:
http-get::audio/vorbis:
http-get::audio/x-vorbis:
http-get::audio/dff:
http-get::audio/x-dff:
http-get::audio/dsf:
http-get::audio/x-dsf:
http-get::audio/:*
DLNA 1.5: Yes
Gapless playback: Yes
Missing events workaround: No
Can play native DSD: Yes
2 ch Integer PCM 24bit little endian 352.8kHz
2 ch Integer PCM 24bit little endian 705.6kHz
2 ch Integer PCM 24bit little endian 384kHz
2 ch Integer PCM 24bit little endian 768kHz
2 ch DSD 8bit little endian in 8bit chunk 2822.4kHz
2 ch DSD 8bit little endian in 8bit chunk 5644.8kHz
2 ch DSD 8bit little endian in 8bit chunk 11289.6kHz
2 ch DSD 8bit little endian in 8bit chunk 22579.2kHz
CurrentTransportState: TRANSITIONING
NrTracks: 1
MediaDuration: 0:00:00
CurrentURI:
CurrentURIMetadata: NOT_IMPLEMENTED
nextURI:
PlayMedium: NONE
<?xml version="1.0"?> 1 0 TransportState string STOPPED PAUSED_PLAYBACK PLAYING TRANSITIONING STOPPED TransportStatus string OK PlaybackStorageMedium string NONE RecordStorageMedium string NOT_IMPLEMENTED PossiblePlaybackStorageMedia string NETWORK PossibleRecordStorageMedia string NOT_IMPLEMENTED CurrentPlayMode string NORMAL NORMAL TransportPlaySpeed string 1 1 RecordMediumWriteStatus string NOT_IMPLEMENTED CurrentRecordQualityMode string NOT_IMPLEMENTED PossibleRecordQualityModes string NOT_IMPLEMENTED NumberOfTracks ui4 0 CurrentTrack ui4 0 1 CurrentTrackDuration string CurrentMediaDuration string CurrentTrackMetaData string CurrentTrackURI string AVTransportURI string AVTransportURIMetaData string NextAVTransportURI string NextAVTransportURIMetaData string RelativeTimePosition string AbsoluteTimePosition string RelativeCounterPosition i4 AbsoluteCounterPosition i4 CurrentTransportActions string LastChange string A_ARG_TYPE_SeekMode string TRACK_NR REL_TIME ABS_TIME A_ARG_TYPE_SeekTarget string A_ARG_TYPE_InstanceID ui4 SetNextAVTransportURI InstanceID in A_ARG_TYPE_InstanceID NextURI in NextAVTransportURI NextURIMetaData in NextAVTransportURIMetaData SetAVTransportURI InstanceID in A_ARG_TYPE_InstanceID CurrentURI in AVTransportURI CurrentURIMetaData in AVTransportURIMetaData GetMediaInfo InstanceID in A_ARG_TYPE_InstanceID NrTracks out NumberOfTracks MediaDuration out CurrentMediaDuration CurrentURI out AVTransportURI CurrentURIMetaData out AVTransportURIMetaData NextURI out NextAVTransportURI NextURIMetaData out NextAVTransportURIMetaData PlayMedium out PlaybackStorageMedium RecordMedium out RecordStorageMedium WriteStatus out RecordMediumWriteStatus GetTransportInfo InstanceID in A_ARG_TYPE_InstanceID CurrentTransportState out TransportState CurrentTransportStatus out TransportStatus CurrentSpeed out TransportPlaySpeed GetPositionInfo InstanceID in A_ARG_TYPE_InstanceID Track out CurrentTrack TrackDuration out CurrentTrackDuration TrackMetaData out CurrentTrackMetaData TrackURI out CurrentTrackURI RelTime out RelativeTimePosition AbsTime out AbsoluteTimePosition RelCount out RelativeCounterPosition AbsCount out AbsoluteCounterPosition GetDeviceCapabilities InstanceID in A_ARG_TYPE_InstanceID PlayMedia out PossiblePlaybackStorageMedia RecMedia out PossibleRecordStorageMedia RecQualityModes out PossibleRecordQualityModes GetTransportSettings InstanceID in A_ARG_TYPE_InstanceID PlayMode out CurrentPlayMode RecQualityMode out CurrentRecordQualityMode Stop InstanceID in A_ARG_TYPE_InstanceID Play InstanceID in A_ARG_TYPE_InstanceID Speed in TransportPlaySpeed Pause InstanceID in A_ARG_TYPE_InstanceID Seek InstanceID in A_ARG_TYPE_InstanceID Unit in A_ARG_TYPE_SeekMode Target in A_ARG_TYPE_SeekTarget Next InstanceID in A_ARG_TYPE_InstanceID Previous InstanceID in A_ARG_TYPE_InstanceID SetPlayMode InstanceID in A_ARG_TYPE_InstanceID NewPlayMode in CurrentPlayMode GetCurrentTransportActions InstanceID in A_ARG_TYPE_InstanceID Actions out CurrentTransportActionsCurrent device RootDevice description:
<?xml version="1.0"?> 1 0 urn:schemas-upnp-org:device:MediaRenderer:1 CXNv2 GCS Cambridge Audio http://www.cambridgeaudio.com/ CXNv2 3763 uuid:36d41bac-4a16-485c-9959-ffbfc9d27778 00206612 image/png 48 48 8 /36d41bac-4a16-485c-9959-ffbfc9d27778/CA-roundal-48x48.png image/jpeg 48 48 24 /36d41bac-4a16-485c-9959-ffbfc9d27778/CA-roundal-48x48.jpg image/png 120 120 8 /36d41bac-4a16-485c-9959-ffbfc9d27778/CA-roundal-120x120.png image/jpeg 120 120 24 /36d41bac-4a16-485c-9959-ffbfc9d27778/CA-roundal-120x120.jpg urn:schemas-upnp-org:service:RenderingControl:1 urn:upnp-org:serviceId:RenderingControl /36d41bac-4a16-485c-9959-ffbfc9d27778/RenderingControl/RenderingControl1.xml /36d41bac-4a16-485c-9959-ffbfc9d27778/RenderingControl/invoke /36d41bac-4a16-485c-9959-ffbfc9d27778/RenderingControl/event urn:schemas-upnp-org:service:ConnectionManager:1 urn:upnp-org:serviceId:ConnectionManager /36d41bac-4a16-485c-9959-ffbfc9d27778/ConnectionManager/ConnectionManager1.xml /36d41bac-4a16-485c-9959-ffbfc9d27778/ConnectionManager/invoke /36d41bac-4a16-485c-9959-ffbfc9d27778/ConnectionManager/event urn:schemas-upnp-org:service:ContentDirectory:1 urn:upnp-org:serviceId:ContentDirectory /36d41bac-4a16-485c-9959-ffbfc9d27778/ContentDirectory/ContentDirectory1.xml /36d41bac-4a16-485c-9959-ffbfc9d27778/ContentDirectory/invoke /36d41bac-4a16-485c-9959-ffbfc9d27778/ContentDirectory/event urn:schemas-upnp-org:service:AVTransport:1 urn:upnp-org:serviceId:AVTransport /36d41bac-4a16-485c-9959-ffbfc9d27778/AVTransport/AVTransport1.xml /36d41bac-4a16-485c-9959-ffbfc9d27778/AVTransport/invoke /36d41bac-4a16-485c-9959-ffbfc9d27778/AVTransport/event urn:UuVol-com:service:UuVolControl:5 urn:UuVol-com:serviceId:UuVolControl /36d41bac-4a16-485c-9959-ffbfc9d27778/RecivaRadio/RecivaRadio.xml /36d41bac-4a16-485c-9959-ffbfc9d27778/RecivaRadio/invoke /36d41bac-4a16-485c-9959-ffbfc9d27778/RecivaRadio/event urn:UuVol-com:service:PlaylistExtension:1 urn:UuVol-com:serviceId:PlaylistExtension /36d41bac-4a16-485c-9959-ffbfc9d27778/UuPlaylist/Playlist.xml /36d41bac-4a16-485c-9959-ffbfc9d27778/UuPlaylist/invoke /36d41bac-4a16-485c-9959-ffbfc9d27778/UuPlaylist/event urn:UuVol-com:service:UuVolSimpleRemote:1 urn:UuVol-com:serviceId:UuVolSimpleRemote /36d41bac-4a16-485c-9959-ffbfc9d27778/RecivaSimpleRemote/RecivaSimpleRemote.xml /36d41bac-4a16-485c-9959-ffbfc9d27778/RecivaSimpleRemote/invoke /36d41bac-4a16-485c-9959-ffbfc9d27778/RecivaSimpleRemote/event urn:UuVol-com:service:StreamMagic6:1 urn:UuVol-com:serviceId:StreamMagic6 /36d41bac-4a16-485c-9959-ffbfc9d27778/StreamMagic6/StreamMagic6.xml /36d41bac-4a16-485c-9959-ffbfc9d27778/StreamMagic6/invoke /36d41bac-4a16-485c-9959-ffbfc9d27778/StreamMagic6/event urn:UuVol-com:service:SMSearch:1 urn:UuVol-com:serviceId:SMSearch /36d41bac-4a16-485c-9959-ffbfc9d27778/SMSearch/SMSearch.xml /36d41bac-4a16-485c-9959-ffbfc9d27778/SMSearch/invoke /36d41bac-4a16-485c-9959-ffbfc9d27778/SMSearch/event DMR-1.50 M-DMP-1.50UPnP devices found : 1
Device #0CXNv2 GCS UID: uuid:36d41bac-4a16-485c-9959-ffbfc9d27778 Location: http://192.168.0.16:8050/36d41bac-4a16-485c-9959-ffbfc9d27778/description.xml
Max. memory for audio buffers: 28066MB
Local Audio Engine:WASAPI
Local devices found : 5
Device #0: Speakers (USB MICROPHONE ) Manufacturer: Model UID: Speakers (USB MICROPHONE ) UID: \?\SWD#MMDEVAPI#{0.0.0.00000000}.{5c121cdd-e20f-43ef-8dbd-6caee88e75b5}#{e6327cad-dcec-4949-ae8a-991e976a79d2}
Device #1: Realtek HD Audio 2nd output (Realtek® Audio) Manufacturer: Model UID: Realtek HD Audio 2nd output (Realtek® Audio) UID: \?\SWD#MMDEVAPI#{0.0.0.00000000}.{991f610c-89d2-491d-80ee-b7636b0edaff}#{e6327cad-dcec-4949-ae8a-991e976a79d2}
Device #2: PL2730H (2- NVIDIA High Definition Audio) Manufacturer: Model UID: PL2730H (2- NVIDIA High Definition Audio) UID: \?\SWD#MMDEVAPI#{0.0.0.00000000}.{7b00458e-e86a-4c62-aba6-84809bd47e84}#{e6327cad-dcec-4949-ae8a-991e976a79d2}
Device #3: Haut-parleurs (Realtek® Audio) Manufacturer: Model UID: Haut-parleurs (Realtek® Audio) UID: \?\SWD#MMDEVAPI#{0.0.0.00000000}.{ffcb23a2-d108-42d0-94af-785736d4f14b}#{e6327cad-dcec-4949-ae8a-991e976a79d2}
Device #4: PL2730H (2- NVIDIA High Definition Audio) Manufacturer: Model UID: PL2730H (2- NVIDIA High Definition Audio) UID: \?\SWD#MMDEVAPI#{0.0.0.00000000}.{55911579-a3d3-49a6-853f-d4fe8baa6972}#{e6327cad-dcec-4949-ae8a-991e976a79d2}
