Dear community,
when I try to play a song with Audirvāna Studio over my network player CXNv2 (current firmware release) I’ll get the following error message: “Loading first track…”.
Audirvāna 3.5.45 works fine.
Any ideas?
Best regards
Rob
Debug Info:
Current version: 1.0.0 (10000)
Connected account: xxxxxxxx
Bandwidth at 0dB = 99.5%
Phase = 66%
Sync list: 2 folders
AUTO: D:\Productions
AUTO: D:\Selections
Library database path: C:\Users\Robert\AppData\Local\Audirvana\Audirvana\AudirvanaDatabase.sqlite
Listening on fd00::65b7:8416:96aa:2aec on port 53093
Preferred device: Cambridge Audio CXNv2 Model UID:Cambridge Audio CXNv2 UID:uuid:2ac8f606-22c3-45dc-8ebf-a0eddf795d3f
UPnP device at http://192.168.178.26:8050/2ac8f606-22c3-45dc-8ebf-a0eddf795d3f/description.xml
CXNv2
Manufacturer: Cambridge Audio
Model Name:
Model UID: Cambridge Audio CXNv2
UID: uuid:2ac8f606-22c3-45dc-8ebf-a0eddf795d3f
8 available sample rates up to 5644800Hz
5644800
Volume control: No
DSD capability: Raw DSD (MSB)
http-get::audio/x-ms-wma:DLNA.ORG_PN=WMALSL
http-get::audio/mpeg:
http-get::audio/m4a:
http-get::audio/x-m4a:
http-get::audio/aac:
http-get::audio/wave:
http-get::audio/wav:
http-get::audio/x-wav:
http-get::audio/aiff:
http-get::audio/x-aiff:
http-get::audio/flac:
http-get::audio/x-flac:
http-get::audio/ation/ogg:
http-get::audio/ogg:
http-get::audio/vorbis:
http-get::audio/x-vorbis:
http-get::audio/dff:
http-get::audio/x-dff:
http-get::audio/dsf:
http-get::audio/x-dsf:
http-get::audio/:*
DLNA 1.5: Yes
Gapless playback: Yes
Missing events workaround: No
Can play native DSD: Yes
CurrentTransportState: TRANSITIONING
NrTracks: 1
MediaDuration: 0:00:00
CurrentURI:
CurrentURIMetadata: NOT_IMPLEMENTED
nextURI:
PlayMedium: NONE
<?xml version="1.0"?> 1 0 TransportState string STOPPED PAUSED_PLAYBACK PLAYING TRANSITIONING STOPPED TransportStatus string OK PlaybackStorageMedium string NONE RecordStorageMedium string NOT_IMPLEMENTED PossiblePlaybackStorageMedia string NETWORK PossibleRecordStorageMedia string NOT_IMPLEMENTED CurrentPlayMode string NORMAL NORMAL TransportPlaySpeed string 1 1 RecordMediumWriteStatus string NOT_IMPLEMENTED CurrentRecordQualityMode string NOT_IMPLEMENTED PossibleRecordQualityModes string NOT_IMPLEMENTED NumberOfTracks ui4 0 CurrentTrack ui4 0 1 CurrentTrackDuration string CurrentMediaDuration string CurrentTrackMetaData string CurrentTrackURI string AVTransportURI string AVTransportURIMetaData string NextAVTransportURI string NextAVTransportURIMetaData string RelativeTimePosition string AbsoluteTimePosition string RelativeCounterPosition i4 AbsoluteCounterPosition i4 CurrentTransportActions string LastChange string A_ARG_TYPE_SeekMode string TRACK_NR REL_TIME ABS_TIME A_ARG_TYPE_SeekTarget string A_ARG_TYPE_InstanceID ui4 SetNextAVTransportURI InstanceID in A_ARG_TYPE_InstanceID NextURI in NextAVTransportURI NextURIMetaData in NextAVTransportURIMetaData SetAVTransportURI InstanceID in A_ARG_TYPE_InstanceID CurrentURI in AVTransportURI CurrentURIMetaData in AVTransportURIMetaData GetMediaInfo InstanceID in A_ARG_TYPE_InstanceID NrTracks out NumberOfTracks MediaDuration out CurrentMediaDuration CurrentURI out AVTransportURI CurrentURIMetaData out AVTransportURIMetaData NextURI out NextAVTransportURI NextURIMetaData out NextAVTransportURIMetaData PlayMedium out PlaybackStorageMedium RecordMedium out RecordStorageMedium WriteStatus out RecordMediumWriteStatus GetTransportInfo InstanceID in A_ARG_TYPE_InstanceID CurrentTransportState out TransportState CurrentTransportStatus out TransportStatus CurrentSpeed out TransportPlaySpeed GetPositionInfo InstanceID in A_ARG_TYPE_InstanceID Track out CurrentTrack TrackDuration out CurrentTrackDuration TrackMetaData out CurrentTrackMetaData TrackURI out CurrentTrackURI RelTime out RelativeTimePosition AbsTime out AbsoluteTimePosition RelCount out RelativeCounterPosition AbsCount out AbsoluteCounterPosition GetDeviceCapabilities InstanceID in A_ARG_TYPE_InstanceID PlayMedia out PossiblePlaybackStorageMedia RecMedia out PossibleRecordStorageMedia RecQualityModes out PossibleRecordQualityModes GetTransportSettings InstanceID in A_ARG_TYPE_InstanceID PlayMode out CurrentPlayMode RecQualityMode out CurrentRecordQualityMode Stop InstanceID in A_ARG_TYPE_InstanceID Play InstanceID in A_ARG_TYPE_InstanceID Speed in TransportPlaySpeed Pause InstanceID in A_ARG_TYPE_InstanceID Seek InstanceID in A_ARG_TYPE_InstanceID Unit in A_ARG_TYPE_SeekMode Target in A_ARG_TYPE_SeekTarget Next InstanceID in A_ARG_TYPE_InstanceID Previous InstanceID in A_ARG_TYPE_InstanceID SetPlayMode InstanceID in A_ARG_TYPE_InstanceID NewPlayMode in CurrentPlayMode GetCurrentTransportActions InstanceID in A_ARG_TYPE_InstanceID Actions out CurrentTransportActionsCurrent device RootDevice description:
<?xml version="1.0"?> 1 0 urn:schemas-upnp-org:device:MediaRenderer:1 CXNv2 Cambridge Audio http://www.cambridgeaudio.com/ CXNv2 3475 uuid:2ac8f606-22c3-45dc-8ebf-a0eddf795d3f 002033b6 image/png 48 48 8 /2ac8f606-22c3-45dc-8ebf-a0eddf795d3f/CA-roundal-48x48.png image/jpeg 48 48 24 /2ac8f606-22c3-45dc-8ebf-a0eddf795d3f/CA-roundal-48x48.jpg image/png 120 120 8 /2ac8f606-22c3-45dc-8ebf-a0eddf795d3f/CA-roundal-120x120.png image/jpeg 120 120 24 /2ac8f606-22c3-45dc-8ebf-a0eddf795d3f/CA-roundal-120x120.jpg urn:schemas-upnp-org:service:RenderingControl:1 urn:upnp-org:serviceId:RenderingControl /2ac8f606-22c3-45dc-8ebf-a0eddf795d3f/RenderingControl/RenderingControl1.xml /2ac8f606-22c3-45dc-8ebf-a0eddf795d3f/RenderingControl/invoke /2ac8f606-22c3-45dc-8ebf-a0eddf795d3f/RenderingControl/event urn:schemas-upnp-org:service:ConnectionManager:1 urn:upnp-org:serviceId:ConnectionManager /2ac8f606-22c3-45dc-8ebf-a0eddf795d3f/ConnectionManager/ConnectionManager1.xml /2ac8f606-22c3-45dc-8ebf-a0eddf795d3f/ConnectionManager/invoke /2ac8f606-22c3-45dc-8ebf-a0eddf795d3f/ConnectionManager/event urn:schemas-upnp-org:service:ContentDirectory:1 urn:upnp-org:serviceId:ContentDirectory /2ac8f606-22c3-45dc-8ebf-a0eddf795d3f/ContentDirectory/ContentDirectory1.xml /2ac8f606-22c3-45dc-8ebf-a0eddf795d3f/ContentDirectory/invoke /2ac8f606-22c3-45dc-8ebf-a0eddf795d3f/ContentDirectory/event urn:schemas-upnp-org:service:AVTransport:1 urn:upnp-org:serviceId:AVTransport /2ac8f606-22c3-45dc-8ebf-a0eddf795d3f/AVTransport/AVTransport1.xml /2ac8f606-22c3-45dc-8ebf-a0eddf795d3f/AVTransport/invoke /2ac8f606-22c3-45dc-8ebf-a0eddf795d3f/AVTransport/event urn:UuVol-com:service:UuVolControl:5 urn:UuVol-com:serviceId:UuVolControl /2ac8f606-22c3-45dc-8ebf-a0eddf795d3f/RecivaRadio/RecivaRadio.xml /2ac8f606-22c3-45dc-8ebf-a0eddf795d3f/RecivaRadio/invoke /2ac8f606-22c3-45dc-8ebf-a0eddf795d3f/RecivaRadio/event urn:UuVol-com:service:PlaylistExtension:1 urn:UuVol-com:serviceId:PlaylistExtension /2ac8f606-22c3-45dc-8ebf-a0eddf795d3f/UuPlaylist/Playlist.xml /2ac8f606-22c3-45dc-8ebf-a0eddf795d3f/UuPlaylist/invoke /2ac8f606-22c3-45dc-8ebf-a0eddf795d3f/UuPlaylist/event urn:UuVol-com:service:UuVolSimpleRemote:1 urn:UuVol-com:serviceId:UuVolSimpleRemote /2ac8f606-22c3-45dc-8ebf-a0eddf795d3f/RecivaSimpleRemote/RecivaSimpleRemote.xml /2ac8f606-22c3-45dc-8ebf-a0eddf795d3f/RecivaSimpleRemote/invoke /2ac8f606-22c3-45dc-8ebf-a0eddf795d3f/RecivaSimpleRemote/event urn:UuVol-com:service:StreamMagic6:1 urn:UuVol-com:serviceId:StreamMagic6 /2ac8f606-22c3-45dc-8ebf-a0eddf795d3f/StreamMagic6/StreamMagic6.xml /2ac8f606-22c3-45dc-8ebf-a0eddf795d3f/StreamMagic6/invoke /2ac8f606-22c3-45dc-8ebf-a0eddf795d3f/StreamMagic6/event urn:UuVol-com:service:SMSearch:1 urn:UuVol-com:serviceId:SMSearch /2ac8f606-22c3-45dc-8ebf-a0eddf795d3f/SMSearch/SMSearch.xml /2ac8f606-22c3-45dc-8ebf-a0eddf795d3f/SMSearch/invoke /2ac8f606-22c3-45dc-8ebf-a0eddf795d3f/SMSearch/event DMR-1.50 M-DMP-1.50UPnP devices found : 1
Device #0CXNv2 UID: uuid:2ac8f606-22c3-45dc-8ebf-a0eddf795d3f Location: http://192.168.178.26:8050/2ac8f606-22c3-45dc-8ebf-a0eddf795d3f/description.xml
Max. memory for audio buffers: 4230MB
Local devices found : 3
Device #0: Line (3- Henry Audio USB DAC 128 Mk 3) Manufacturer: Microsoft Model UID: USB\VID_16D0&PID_075D&REV_1000&MI_00 UID: \?\SWD#MMDEVAPI#{0.0.0.00000000}.{e1ac2be6-4b3e-4466-a50d-44b849d60d86}#{e6327cad-dcec-4949-ae8a-991e976a79d2} Model Name: Henry Audio USB DAC 128 Mk 3
Device #1: Line (Henry Audio USB DAC 128 Mk 3) Manufacturer: Microsoft Model UID: USB\VID_16D0&PID_075D&REV_1000&MI_00 UID: \?\SWD#MMDEVAPI#{0.0.0.00000000}.{676821f6-0b02-4cc6-9010-ac1787561f1f}#{e6327cad-dcec-4949-ae8a-991e976a79d2} Model Name: Henry Audio USB DAC 128 Mk 3
Device #2: P27T-7 LED (Intel® Display Audio) Manufacturer: Intel® Corporation Model UID: HDAUDIO\FUNC_01&VEN_8086&DEV_280B&SUBSYS_80860101&REV_1000 UID: \?\SWD#MMDEVAPI#{0.0.0.00000000}.{60855c3d-33d0-48e2-ae2f-ceead8846284}#{e6327cad-dcec-4949-ae8a-991e976a79d2} Model Name: Unknown manufacturer
