Cyrus Pre2 DAC QXR
Hi,
Trialling Audivarna at the mo but have a problem. I have one of the above connected via USB. Cyrus Driver is ASIO compatible, see below.
I can can set it as ASIO in Audivarna but device does not connect. Any Ideas?
Thx
Craig
Hi,
Solved the issue. I simply removed and re-installed the latest Cyrus driver, not sure if the problem was with the driver version or whether a re-install of the same version would have worked too.
Thx
Craig
