I have a Meze 99 Classic and an Ifi Air Dac
When I play music on Audirvana, only the application can play sound. Which is certainly good in terms of quality, but Iād like to have the sound of the rest + the sound of Audirvana, even if it means sacrificing a little quality.
When Iām in WASAPI, when I uncheck the padlock, the sound comes right back.
When Iām in ASIO, when I uncheck the padlock, the sound remains blocked on my PC, so I have to close the application Audirvana.
By the way: when my headset doesnāt receive sound for a few seconds, I hear a little sizzle, then as soon as the sound comes back, sizzle again. Itās as if as soon as the headset isnāt playing something, it goes into standby mode, and when itās turned back on, it creates crackling noises. I should point out that none of these problems existed when I bought this DAC.
This is due to the exclusive mode of WASPAI that need to be enabled to get playback by AudirvÄna. For the moment, we chose to not add the option to disable the option but it may be possible in the future in a update.
Are you using the latest version of the ASIO driver/firmware for your iFi device?
I canāt reproduce your behavior over WASAPI, I need to select the output again when I click on the padlock to get the audio again of a YouTube video through the Neo iDSD I have here.
For ASIO, can you check in the Windows settings if the device is still here when you click on the padlock?
In the case of the firmware version you have, you are using the latest one so you are good to go.
