Hi All,
I am just getting aquatinted with Audirvana and installed Studio 2.2.3 on MacBook Air with DACMagic 200M. So far so good (except for major gripe about Artist/Track radio for Tidal )
However for some reason AS listd usb attached DAC as not MQA capable
I’m not sure what screenshot you’re posting, could you please post the entire thing?
Take a look at your DAC input settings and see if it’s set as a decoder.
Is it confusing? I read it as IF not MQA capable then force decoder, so if the DAC is mqa capable then that bit is irrelevent?
But this is grown up stuff so I should maybe shut up!
My DAC is fully capable of MQA, whether or not I choose auto detect it shows “not MQA capable & force decoder“ It just seems odd to me, it’s working fine as far as I can tell.
Ok guys so there is something in the iOS and Android app we need to fix when a MQA Decoder is connected. Note that it only affects MQA Decoder device, not MQA Renderer.
