This is possible due to UWP implementation, since Audirvana is a UWP it can store data in this section
and if you uninstall Audirvana, the location after package will be automatically deleted.
Thank you@damien3 I have uninstalled Audirvana and I will check where it rebuilds its database tomorrow when it allows me to re-install.
Another minor matter. You MUST do something about the revoke/reinstall 24 hour delay. This is softtware for which I have paid and it’s on my PC, I should NOT have to wait a day to re-install. Uninstall/reinstall is one of the most common things to try in order to fix issues. The delay is not really acceptable, is it?
I have now re-installed Audirvana and the database has been created in exactly the same location as previously. i.e. NOT in the location advised in Settings.
This is a potential source of confusion and should be rectified. I don’t much care but others might.
