Hello Damien,
Some questions about work A+ with dCS Debussy DAC connected via USB to mac.
- How can I hide or disable the software’s volume control in A+ and A+Remote? I set “DAC only” but volume slider still active.
- Which option will be used most correctly? DoP 1.0, DoP 1.1 or dCS initial method ?
- What DSD filter is better to use when converting all file types to DSD?
Maybe someone else will be able to share his best practices with A+ and dCS Debussy ?
