dCS Network Bridge
UPNP:
Detection:
PCM supported sample rate : 44.1 - 48 - 88,2 - 96 - 175,4 - 192 - 354 - 384
DSD supported sample rate : 64 - 128
DSD Over PCM setting : None
MQA capability : Decoder
Volume:
Volume can be changed : Yes
Device can mute - unmute: Yes
Playback:
Setting do not send RAW PCM activated : No
Playback Control:
Gapless playbak option enabled : No
Hi Antoine, when you say that volume can be changed when using the dCS network bridge over UPNP, do you mean that one can change the volume from the Audirvana Remote? Or that one can use the dCS native app to control the volume while audirvana streams via UPNP?
Both If I recall the tests I made back in the day :wink:
