Crashing, several times each day!!!
Audirvana Studio 1.7.1 (10701)
macOS 10.15 with 16GB physical RAM
AU plugin #0: Effect - Sonarworks SoundID Reference Plugin ()
AU plugin #1: None
AU plugin #2: None
AU plugin #3: None
Replay Gain: by track
SW volume control: ON
Sync list: 2 folders
AUTO: /Volumes/Data-1/Muziek Media/Audirvana Bibliotheek/Media
AUTO: /Volumes/Data-1/Muziek Media/Muziek Bibliotheek/Media.localized
Library database path: /Users/JosvanGeffen/Library/Application Support/Audirvana/AudirvanaDatabase.sqlite
Listening on 127.0.0.1 on port 65083
Preferred device: YAMAHA CORPORATION YAMAHA PLAYER Model UID:Yamaha Corporation Yamaha Player UID:uuid:9ab0c000-f668-11de-9976-ac44f285ce26
UPnP device at http://10.0.1.3:49154/MediaRenderer/desc.xml
ID 0x0 Yamaha Player
Manufacturer: Yamaha Corporation
Model Name:
Model UID: Yamaha Corporation Yamaha Player
UID: uuid:9ab0c000-f668-11de-9976-ac44f285ce26
12 available sample rates up to 96000Hz
8000
11025
12000
16000
22050
24000
32000
Volume control: No
DSD capability: Raw DSD (MSB)
Avoid RAW PCM streams: No
http-get::audio/L16;channels=2;rate=44100:DLNA.ORG_PN=LPCM
http-get::audio/L16;channels=1;rate=44100:DLNA.ORG_PN=LPCM
http-get::audio/L16;channels=2;rate=48000:DLNA.ORG_PN=LPCM
http-get::audio/L16;channels=1;rate=48000:DLNA.ORG_PN=LPCM
http-get::audio/L16;channels=2;rate=32000:DLNA.ORG_PN=LPCM
http-get::audio/L16;channels=1;rate=32000:DLNA.ORG_PN=LPCM
http-get::audio/L16;channels=2;rate=88200:DLNA.ORG_PN=LPCM
http-get::audio/L16;channels=1;rate=88200:DLNA.ORG_PN=LPCM
http-get::audio/L16;channels=2;rate=96000:DLNA.ORG_PN=LPCM
http-get::audio/L16;channels=1;rate=96000:DLNA.ORG_PN=LPCM
http-get::audio/L16;channels=2;rate=64000:DLNA.ORG_PN=LPCM
http-get::audio/L16;channels=1;rate=64000:DLNA.ORG_PN=LPCM
http-get::audio/L16;channels=2;rate=22050:DLNA.ORG_PN=LPCM
http-get::audio/L16;channels=1;rate=22050:DLNA.ORG_PN=LPCM
http-get::audio/L16;channels=2;rate=24000:DLNA.ORG_PN=LPCM
http-get::audio/L16;channels=1;rate=24000:DLNA.ORG_PN=LPCM
http-get::audio/L16;channels=2;rate=16000:DLNA.ORG_PN=LPCM
http-get::audio/L16;channels=1;rate=16000:DLNA.ORG_PN=LPCM
http-get::audio/L16;channels=2;rate=11025:DLNA.ORG_PN=LPCM
http-get::audio/L16;channels=1;rate=11025:DLNA.ORG_PN=LPCM
http-get::audio/L16;channels=2;rate=12000:DLNA.ORG_PN=LPCM
http-get::audio/L16;channels=1;rate=12000:DLNA.ORG_PN=LPCM
http-get::audio/L16;channels=2;rate=8000:DLNA.ORG_PN=LPCM
http-get::audio/L16;channels=1;rate=8000:DLNA.ORG_PN=LPCM
http-get::audio/x-ms-wma:DLNA.ORG_PN=WMDRM_WMABASE
http-get::audio/x-ms-wma:DLNA.ORG_PN=WMDRM_WMAFULL
http-get::audio/vnd.dlna.adts:DLNA.ORG_PN=AAC_ADTS_192
http-get::audio/mp4:DLNA.ORG_PN=AAC_ISO_192
http-get::audio/3gpp:DLNA.ORG_PN=AAC_ISO_192
http-get::audio/x-ms-wma:*
http-get::audio/x-flac:
http-get::audio/x-mpeg:
http-get::audio/x-aac:
http-get::audio/x-mp3:
http-get::audio/x-mp4:
http-get::audio/x-mpg:
http-get::audio/x-wav:
http-get::audio/aacp:
http-get::audio/aiff:
http-get::audio/x-aiff:
http-get::audio/flac:
http-get::audio/mpeg:
http-get::audio/aac:
http-get::audio/m4a:
http-get::audio/mp3:
http-get::audio/dsd:
http-get::audio/x-dsd:
http-get::audio/x-dsf:
http-get::audio/x-dff:
http-get::audio/wav:
DLNA 1.5: Yes
Gapless playback: Yes
Missing events workaround: No
Can play native DSD: Yes
Volume Control: scalar
13 virtual formats:
2 ch Non-mixable linear PCM Interleaved 16 big endian Signed Integer 44.1kHz
2 ch Non-mixable linear PCM Interleaved 16 big endian Signed Integer 48kHz
2 ch Non-mixable linear PCM Interleaved 16 big endian Signed Integer 32kHz
2 ch Non-mixable linear PCM Interleaved 16 big endian Signed Integer 88.2kHz
2 ch Non-mixable linear PCM Interleaved 16 big endian Signed Integer 96kHz
2 ch Non-mixable linear PCM Interleaved 16 big endian Signed Integer 64kHz
2 ch Non-mixable linear PCM Interleaved 16 big endian Signed Integer 22.05kHz
2 ch Non-mixable linear PCM Interleaved 16 big endian Signed Integer 24kHz
2 ch Non-mixable linear PCM Interleaved 16 big endian Signed Integer 16kHz
2 ch Non-mixable linear PCM Interleaved 16 big endian Signed Integer 11.025kHz
2 ch Non-mixable linear PCM Interleaved 16 big endian Signed Integer 12kHz
2 ch Non-mixable linear PCM Interleaved 16 big endian Signed Integer 8kHz
0 physical formats
NrTracks: 1
MediaDuration: 0:00:00
CurrentURI: http://10.0.1.21:49152/audirvana/audioTest.pcm
CurrentURIMetadata: dc:titletestTitle</dc:title> upnp:classobject.item.audioItem.musicTrack</upnp:class> http://10.0.1.21:49152/audirvana/audioTest.pcm
nextURI:
nextURIMetadata:
PlayMedium: NETWORK
<?xml version="1.0"?> 1 0 SetAVTransportURI InstanceID in A_ARG_TYPE_InstanceID CurrentURI in AVTransportURI CurrentURIMetaData in AVTransportURIMetaData SetNextAVTransportURI InstanceID in A_ARG_TYPE_InstanceID NextURI in NextAVTransportURI NextURIMetaData in NextAVTransportURIMetaData GetMediaInfo InstanceID in A_ARG_TYPE_InstanceID NrTracks out NumberOfTracks MediaDuration out CurrentMediaDuration CurrentURI out AVTransportURI CurrentURIMetaData out AVTransportURIMetaData NextURI out NextAVTransportURI NextURIMetaData out NextAVTransportURIMetaData PlayMedium out PlaybackStorageMedium RecordMedium out RecordStorageMedium WriteStatus out RecordMediumWriteStatus GetTransportInfo InstanceID in A_ARG_TYPE_InstanceID CurrentTransportState out TransportState CurrentTransportStatus out TransportStatus CurrentSpeed out TransportPlaySpeed GetPositionInfo InstanceID in A_ARG_TYPE_InstanceID Track out CurrentTrack TrackDuration out CurrentTrackDuration TrackMetaData out CurrentTrackMetaData TrackURI out CurrentTrackURI RelTime out RelativeTimePosition AbsTime out AbsoluteTimePosition RelCount out RelativeCounterPosition AbsCount out AbsoluteCounterPosition GetDeviceCapabilities InstanceID in A_ARG_TYPE_InstanceID PlayMedia out PossiblePlaybackStorageMedia RecMedia out PossibleRecordStorageMedia RecQualityModes out PossibleRecordQualityModes GetTransportSettings InstanceID in A_ARG_TYPE_InstanceID PlayMode out CurrentPlayMode RecQualityMode out CurrentRecordQualityMode Stop InstanceID in A_ARG_TYPE_InstanceID Play InstanceID in A_ARG_TYPE_InstanceID Speed in TransportPlaySpeed Pause InstanceID in A_ARG_TYPE_InstanceID Seek InstanceID in A_ARG_TYPE_InstanceID Unit in A_ARG_TYPE_SeekMode Target in A_ARG_TYPE_SeekTarget Next InstanceID in A_ARG_TYPE_InstanceID Previous InstanceID in A_ARG_TYPE_InstanceID GetCurrentTransportActions InstanceID in A_ARG_TYPE_InstanceID Actions out CurrentTransportActions TransportState string STOPPED PAUSED_PLAYBACK PLAYING TRANSITIONING NO_MEDIA_PRESENT TransportStatus string OK ERROR_OCCURRED PlaybackStorageMedium string NETWORK NONE RecordStorageMedium string NOT_IMPLEMENTED PossiblePlaybackStorageMedia string PossibleRecordStorageMedia string CurrentPlayMode string NORMAL NORMAL TransportPlaySpeed string 1 RecordMediumWriteStatus string NOT_IMPLEMENTED CurrentRecordQualityMode string NOT_IMPLEMENTED PossibleRecordQualityModes string NumberOfTracks ui4 0 1 CurrentTrack ui4 0 1 1 CurrentTrackDuration string CurrentMediaDuration string CurrentTrackMetaData string CurrentTrackURI string AVTransportURI string AVTransportURIMetaData string NextAVTransportURI string NextAVTransportURIMetaData string RelativeTimePosition string AbsoluteTimePosition string RelativeCounterPosition i4 AbsoluteCounterPosition i4 CurrentTransportActions string LastChange string A_ARG_TYPE_SeekMode string TRACK_NR REL_TIME A_ARG_TYPE_SeekTarget string A_ARG_TYPE_InstanceID ui4Current device RootDevice description:
<?xml version="1.0"?> 1 0 DMR-1.50 urn:schemas-upnp-org:device:MediaRenderer:1 Yamaha Player Yamaha Corporation http://www.yamaha.com/ MusicCast NP-S303 S303 http://www.yamaha.com/ 00B62C73 uuid:9ab0c000-f668-11de-9976-ac44f285ce26 image/jpeg 48 48 24 /Icons/48x48.jpg image/jpeg 120 120 24 /Icons/120x120.jpg image/png 48 48 24 /Icons/48x48.png image/png 120 120 24 /Icons/120x120.png urn:schemas-upnp-org:service:AVTransport:1 urn:upnp-org:serviceId:AVTransport /AVTransport/desc.xml /AVTransport/ctrl /AVTransport/event urn:schemas-upnp-org:service:RenderingControl:1 urn:upnp-org:serviceId:RenderingControl /RenderingControl/desc.xml /RenderingControl/ctrl /RenderingControl/event urn:schemas-upnp-org:service:ConnectionManager:1 urn:upnp-org:serviceId:ConnectionManager /ConnectionManager/desc.xml /ConnectionManager/ctrl /ConnectionManager/event http://10.0.1.3/ http://10.0.1.3:80/ urn:schemas-yamaha-com:service:X_YamahaRemoteControl:1 /YamahaRemoteControl/ctrl /YamahaRemoteControl/desc.xml urn:schemas-yamaha-com:service:X_YamahaExtendedControl:1 /YamahaExtendedControl/v1/ 1920UPnP devices found : 1
Device #0: ID 0x0 Yamaha Player UID: uuid:9ab0c000-f668-11de-9976-ac44f285ce26 Location: http://10.0.1.3:49154/MediaRenderer/desc.xml
Max. memory for audio buffers: 6028MB
Device #0: ID 0x33 Built-in Output Manufacturer: Apple Inc. Model UID: AppleHDA:6 UID: AppleHDAEngineOutput:1B,0,1,2:0 Model Name: Apple Inc. Built-in Output
Device #1: ID 0x42 Zorloo Ztella USB Audio Manufacturer: Zorloo Model UID: Zorloo Ztella USB Audio:2454:1292 UID: AppleUSBAudioEngine:Zorloo:Zorloo Ztella USB Audio:20191209:1 Model Name: Zorloo Ztella USB Audio
