Audirvana 3.5.44
AUTO: D:\Fichiers\Musique
Library database path: C:\Users\XXXXXXX\AppData\Local\Audirvana\AudirvanaPlus\AudirvanaPlusDatabaseV2.sqlite
Max. memory for audio buffers: 29584MB
Local Audio Engine:ASIO 2 driver version 2
Hi mDAC USB device
Model UID:Hi mDAC USB device
Device: 2ch 32bits Integer, 8 bytes per frame 352.8kHz
Active Sample Rate: 352.8kHz
Hi mDAC USB device Manufacturer:
Model UID:Hi mDAC USB device UID:Hi mDAC USB device
2822400
5644800
11289600
22579200
DSD capability: Raw DSD (MSB)
Device #0: Hi mDAC USB device Manufacturer: Model UID: Hi mDAC USB device UID: Hi mDAC USB device
Device #1: Realtek ASIO Manufacturer: Model UID: Realtek ASIO UID: Realtek ASIO
UPnP devices found : 2
Device #0MusicCast UID: uuid:9ab0c000-f668-11de-9976-ac44f243f799 Location: http://192.168.1.10:49154/MediaRenderer/desc.xml
Device #1décodeur TV d’Orange UID: uuid:00ababad-7947-1048-8a00-8c10d4dfe55b Location: http://192.168.1.15:42300/description.xml
DAC : https://nuprimeaudio.com/product/hi-mdac/
