Not sure if I have a MacMini problem, issue with the latest version of Audirvana, or OS X 10.13.1. Last two change were both made and this problem started cropping up.
I’m seeing delays pulling up album songs or advancing songs in the A+ remote. The dialog opens but doesn’t fill-- just spins waiting for content. At the same time my MacMini remote cannot advance songs either (indicating its not a problem with A+). Things will often catch up and it resumes. If I remotely screen into the MacMini, everything immediately recovers. I see an Audirvana notification dialog quickly slide to the right about notifications (but never get to read the whole thing). Seems to occur with local content and Tidal.
BTW, love the MQA icon indication for Tidal songs!
Audirvana Plus rev. 3.1.7 (3127) debug information:
running on Mac OS X 10.13.1 with 8192MB RAM
User preferences:
Remote control: IR: on, Media Keys: on (with volume control: on)
Playlists
Use UTF-8 for all: on
Start playback at launch with audio file: on
Volume knob control in rotation axis
Sample rate converter
iZotope 64bit SRC with no forced upsampling
Polarity inversion: global=off, per track=on
Volume control
DAC preferred, else SW
Max volume limit = 100.0%
AudioUnits not in use
SysOptimizer enabled:
Priority: Extreme
Spotlight: on
TimeMachine: on
iDevices USB: on
iTunes settings:
iTunes integrated Mode: off
Completely deactivate iTunes playback: on
iTunes volume control: active
iTunes play position control: active
iTunes safe factor: 1
Library settings:
Sync list : 2 folders
Auto: /Users/williamgreen/Music/HDtracks
Auto: /Users/williamgreen/Music/iTunes/iTunes Media
Database path: /Users/williamgreen/Library/Application Support/Audirvana
iTunes Synchronization: inactive
Audio settings:
Hog Mode: on
Direct Mode: off
Integer Mode: on Mode 2
Max Mem for audio buffers: 1536MB
Max Sample rate limit: None
Sample rate switching latency: None
Preferred device: Gungnir Gen 5 Model UID:Gungnir Gen 5:0D8C:0004 UID:AppleUSBAudioEngine:Schiit Audio:Gungnir Gen 5:14100000:1
Device: 2ch Non-mixable linear PCM Interleaved 24bits little endian Signed Integer, 6 bytes per frame 44.1kHz
Hog Mode is on
ID 0x28 Gungnir Gen 5 Manufacturer:Schiit Audio
Physical (analog) volume control: No
Virtual (digital) volume control: No
Stream ID 0x29 2 channels starting at 1
18 virtual formats:
2 ch Mixable linear PCM Interleaved 32 little endian Float 192kHz
2 ch Mixable linear PCM Interleaved 32 little endian Float 176.4kHz
2 ch Mixable linear PCM Interleaved 32 little endian Float 96kHz
2 ch Mixable linear PCM Interleaved 32 little endian Float 88.2kHz
2 ch Mixable linear PCM Interleaved 32 little endian Float 48kHz
2 ch Mixable linear PCM Interleaved 32 little endian Float 44.1kHz
24 physical formats
Local devices found : 4
Device #0: ID 0x2b Built-in Output Manufacturer: Apple Inc. Model UID: AppleHDA:108 UID: AppleHDAEngineOutput:1B,0,1,2:0
Device #1: ID 0x35 HDMI Manufacturer: Apple Inc. Model UID: AppleHDA:108 UID: AppleHDAEngineOutputDP:3,0,1,1:0:{2D4C-0AC8-00000001}
Device #2: ID 0x39 McIntosh-HD HS USB Audio Manufacturer: McIntosh Model UID: McIntosh-HD HS USB Audio:2AFD:0005 UID: AppleUSBAudioEngine:McIntosh:McIntosh HD USB Audio:14210000:2
Device #3: ID 0x28 Gungnir Gen 5 Manufacturer: Schiit Audio Model UID: Gungnir Gen 5:0D8C:0004 UID: AppleUSBAudioEngine:Schiit Audio:Gungnir Gen 5:14100000:1
