I have found that if I delete an album in the Library, when right clicking on the album’s three dots, (for example to correct metadata) if I again add the album, the Library is not updating and adding it.
This occurs even when clicking “Sync”, selecting “Rescan network folders on restart” or closing and re-opening Audirvana. ???
The best way appears to be to simply remove the album using the Finder or Explorer and then adding it again to the music folder.
Then the Audirvava library database behaves correctly.
Hello @aricastudio,
Debug Info:
macOS 10.14.6 with 32768MB RAM
Registered to Juan Contreras
Sync list: 2 folders
AUTO: /Volumes/MUSIC II/Music FLAC
AUTO: /Volumes/MUSIC II/Music MP3
Library database path: /Users/juan/Library/Application Support/Audirvana/AudirvanaPlusDatabaseV2.sqlite
Built-in Digital Output
Model UID:AppleHDA:66
UID:AppleHDAEngineOutput:1B,0,1,5:2
ID 0x33 Built-in Digital Output Manufacturer:Apple Inc.
Model UID:AppleHDA:66 UID:AppleHDAEngineOutput:1B,0,1,5:2
3 available sample rates up to 96000Hz
Stream ID 0x34 2 channels starting at 1
3 virtual formats:
9 physical formats
Local devices found : 4
Device #0: ID 0x40 Built-in Output Manufacturer: Apple Inc. Model UID: AppleHDA:66 UID: AppleHDAEngineOutput:1B,0,1,3:0
Device #1: ID 0x37 Built-in Line Output Manufacturer: Apple Inc. Model UID: AppleHDA:66 UID: AppleHDAEngineOutput:1B,0,1,4:1
Device #2: ID 0x33 Built-in Digital Output Manufacturer: Apple Inc. Model UID: AppleHDA:66 UID: AppleHDAEngineOutput:1B,0,1,5:2
Device #3: ID 0x27 UA-22 Manufacturer: Roland Model UID: UA-22:0582:015A UID: AppleUSBAudioEngine:Roland:UA-22:1d100000:1
The album you have deleted is located here? Have you also deleted form the bin in Audirvana settings in the library section?
Yes it was located in the Music Flac folder, but only deleted inside Library, not in the Mac Finder, so not from the Hard Drive.
I do not know what you are calling the Bin in Audirvana settings?
In tried several things to have Audirvana see the Album in that folder after I updated it, “Sync”, closing and opening Audirvana, checking the “Scan Network folders on Start,” But it would not show up. So I finally deleted the Database, restrarted Audirvana, added the folders in Settings, Library and after it scanned them again it showed up.
Also, I ended up deleting that Album because it had incorrect Metadata, yet after I updated it, Audirvana still displayed the previous incorrect version, not the updated one. So I deleted it in the hope that on the next scan it would show the updated Album.
This problem does not seem to occur if I just delete the Album from the folder in the Finder (OS) and then add it again. Then Audirvana Library updates correctly, on deleting and on adding the Album.
