I need to delete my entire library of about 350 music files. What is the best and easiest way to do it. Hopefully I do not have to use the + and - buttons and delete one at a time.
Delete the database file and rebuild it from scratch.
Hello @randy,
The easiest way would be to remove the synced folder from Audirvana library and delete those files where they are stored in your computer.
Hi Damien,
Where to find the files to delete under windows ?
It’s the default one … I was one sure if I can just delete it ? I now have some duplicate artist names that I am trying to clean up
Audirvana 3.5.45
Per track: OFF
SoX with 2x upsampling
Phase = 80
Max allowed volume: 92.3732
Replay Gain: by album
SW volume control: ON
AUTO: E:
Library database path: C:\Users\Eugene Chng\AppData\Local\Audirvana\AudirvanaPlus\AudirvanaPlusDatabaseV2.sqlite
Max. memory for audio buffers: 13348MB
Local Audio Engine:WASAPI
Speakers (DENAFRIPS USB DAC)
Model UID:Speakers (DENAFRIPS USB DAC)
UID:\?\SWD#MMDEVAPI#{0.0.0.00000000}.{cdb7a5f7-4ff3-42fb-ba0a-41ee19b6f21f}#{e6327cad-dcec-4949-ae8a-991e976a79d2}
Speakers (DENAFRIPS USB DAC) Manufacturer:
Model UID:Speakers (DENAFRIPS USB DAC) UID:\?\SWD#MMDEVAPI#{0.0.0.00000000}.{cdb7a5f7-4ff3-42fb-ba0a-41ee19b6f21f}#{e6327cad-dcec-4949-ae8a-991e976a79d2}
12 available sample rates up to 1536000Hz
1411200
1536000
Simple stereo device: No
2 ch Integer PCM 16bit little endian 1411.2kHz
2 ch Integer PCM 24bit little endian aligned high in 32bit chunk 1411.2kHz
2 ch Integer PCM 32bit little endian 1411.2kHz
2 ch Integer PCM 16bit little endian 1536kHz
2 ch Integer PCM 24bit little endian aligned high in 32bit chunk 1536kHz
2 ch Integer PCM 32bit little endian 1536kHz
Local devices found : 3
Device #0: 1 - SONY TV XV (AMD High Definition Audio Device) Manufacturer: Model UID: 1 - SONY TV XV (AMD High Definition Audio Device) UID: \?\SWD#MMDEVAPI#{0.0.0.00000000}.{efe22dc8-c7d6-487d-a126-fa7a4447bc7d}#{e6327cad-dcec-4949-ae8a-991e976a79d2}
Device #1: Speakers (DENAFRIPS USB DAC) Manufacturer: Model UID: Speakers (DENAFRIPS USB DAC) UID: \?\SWD#MMDEVAPI#{0.0.0.00000000}.{cdb7a5f7-4ff3-42fb-ba0a-41ee19b6f21f}#{e6327cad-dcec-4949-ae8a-991e976a79d2}
Device #2: Speakers (Realtek High Definition Audio) Manufacturer: Model UID: Speakers (Realtek High Definition Audio) UID: \?\SWD#MMDEVAPI#{0.0.0.00000000}.{eb502002-dc35-4ee8-b289-12f690d94ac0}#{e6327cad-dcec-4949-ae8a-991e976a79d2}
UPnP devices found : 1
Device #0[TV] Samsung Q80 Series (65) UID: uuid:d2d80047-ea98-41b1-a167-e3d0ada4c14b Location: http://192.168.1.129:9197/dmr
If you remove E: from your synced folders, do you still have albums displayed in Audirvana?
No … nothing displayed when I remove my E drive … that’s where my music files are stored
Good news … when I put back E … some of the duplicates are gone
