Deleting albums?
is there anyway to delete albums in Studio?
Click on three dots
That doesn’t work. No option. To delete album
If it worked, you delete a single album.
How do you delete from the AS a few dozens or a few hundreds albums that are stored in a folder that you don’t want to synchronize with AS anymore?
I found no way to do it, and was forced to trash the library of AS
Can you please screen shot your page that does not give you option to delete.
Either go to the folder that is synchronising and remove those albums you want to not show in AS
 save them to another folder.
Or, go to Preferences/Local
 and use the rubbish bin on right of file you don"t want to
sync.
Screen Shot 2021-06-05 at 8.48.39 pm
Hi,
I am facing the same issue; I don’t have the option to delete tracks or album
see printscreen attached
I should add that my music is stored in a NAS
I deleted the album in the NAS but it still appears in Audirvana Origin
this issue was not present in the old version of Audirvana
Are they ghost files? in dark mode i can’t see here if they are grey and cannot be played
 you seems to have many of the same files
if they are ghost files and can’t be delete direct in album tracks view, go to the main library and see your albums in tracks view there not in cover view
 then load the ‘Audio File Location’ tab and click on that tab
 up and down
 you will see that the ghosts files are beginning with /volume/
 or Volume/
 can’t remember, they will be grey, not black, can’t be played
 then select all those grey and then, you can delete them
 after in the trash bin, you can make then go forever
 but check they will be sent to the trash for real
 maybe copy those albums first?
Hi guys, make sure you are in LOCAL>Albums when you want to remove an album
