Deleting audirvana
How can I delete Audirvana from Control Panel. It does not show up in the list. Is There another name it’s under? I’m doing so because I cannot delete one of my folders
Hello @gman1,
Welcome to the forum!
I assume you are talking about the Windows (11) version.
Since Audirvana is a Microsoft Store app, you probably won’t find it in the control panel.
Go to Windows Settings\Apps\Installed Apps and uninstall it from there (it is listed as ‘Audirvana Origin’ or ‘Audirvana Studio’ depending on which Audirvana you have). Click on the three dots (…) next to the applications name and choose ‘uninstall’.
Hi @gman1,
Do you mean you can’t remove one of your folders from Audirvāna settings?
