Hello, I have removed all folders from my monitored folders list. Restarted my Mac and still have 600+ folders remaining. Running 3.5.26 version do I have to remove and re-install Audirvana. Any assistance would be greatly appreciated. Thanks
Go to your folders in Audirvana preferences and select all and delete them.
Close Audirvana.
Apple hide the Home Folder in User Library at some time depending on OS System… When you have clicked your Home Folder, and cannot see the Library Folder in there,
just do a ‘‘cmd J’’ to show the folder settings preferences and see at the bottom… click Show Library Folder and then you’ll have access to the rest forever.
Trash All the files in that folder (that is your database of music, back it up! or not).
Deleting the database will erase all your playlists…
before doing that you may want to export them before, if important.
Restart MAC. Enter Serial. Add a folder of Music… and wait till finish loading.
Thank you for the solution. The tip on the playlists was golden.
We are up and proliferating smoothly.
Sincerely K
