Audirvana Mac Version 3.5.41 (3571)
macOS 10.14.6 with 4096MB RAM
AUTO: /Users/guidojongbeis/Documents/Audirvana
Library database path: /Users/guidojongbeis/Library/Application Support/Audirvana/AudirvanaPlusDatabaseV2.sqlite
Max. memory for audio buffers: 1024MB
HDMI
Model UID:AppleHDA:88
UID:AppleHDAEngineOutputDP:1B,3,1,2:0:{EE11-006C-01010101}
ID 0x54 HDMI Manufacturer:Apple Inc.
Model UID:AppleHDA:88 UID:AppleHDAEngineOutputDP:1B,3,1,2:0:{EE11-006C-01010101}
5 available sample rates up to 96000Hz
32000
Multichannel: 8 channels
Channel bitmap: Ox3f, layout:
Channel 2 mapped to 2
Channel 3 mapped to 3
Channel 4 mapped to 4
Channel 5 mapped to 5
Channel 6 unused
Channel 7 unused
Number of channels: 8
Simple stereo device: No
Number of active channels: 8, in 1 stream(s)
Channel #6 :Stream 0 channel 6
Channel #7 :Stream 0 channel 7
Stream ID 0x55 8 channels starting at 1
8 virtual formats:
8 ch Mixable linear PCM Interleaved 32 little endian Signed Float 96kHz
8 ch Mixable linear PCM Interleaved 32 little endian Signed Float 88.2kHz
8 ch Mixable linear PCM Interleaved 32 little endian Signed Float 48kHz
8 ch Mixable linear PCM Interleaved 32 little endian Signed Float 44.1kHz
8 ch Mixable linear PCM Interleaved 32 little endian Signed Float 32kHz
18 physical formats
8 ch Mixable linear PCM Interleaved 24 little endian Signed Integer aligned low in 32bit 96kHz
8 ch Mixable linear PCM Interleaved 24 little endian Signed Integer aligned low in 32bit 88.2kHz
8 ch Mixable linear PCM Interleaved 24 little endian Signed Integer aligned low in 32bit 48kHz
8 ch Mixable linear PCM Interleaved 24 little endian Signed Integer aligned low in 32bit 44.1kHz
8 ch Mixable linear PCM Interleaved 24 little endian Signed Integer aligned low in 32bit 32kHz
8 ch Mixable linear PCM Interleaved 20 little endian Signed Integer aligned low in 32bit 96kHz
8 ch Mixable linear PCM Interleaved 20 little endian Signed Integer aligned low in 32bit 88.2kHz
8 ch Mixable linear PCM Interleaved 20 little endian Signed Integer aligned low in 32bit 48kHz
8 ch Mixable linear PCM Interleaved 20 little endian Signed Integer aligned low in 32bit 44.1kHz
8 ch Mixable linear PCM Interleaved 20 little endian Signed Integer aligned low in 32bit 32kHz
8 ch Mixable linear PCM Interleaved 16 little endian Signed Integer 96kHz
8 ch Mixable linear PCM Interleaved 16 little endian Signed Integer 88.2kHz
8 ch Mixable linear PCM Interleaved 16 little endian Signed Integer 48kHz
8 ch Mixable linear PCM Interleaved 16 little endian Signed Integer 44.1kHz
8 ch Mixable linear PCM Interleaved 16 little endian Signed Integer 32kHz
Local devices found : 3
Device #0: ID 0x4d Built-in Output Manufacturer: Apple Inc. Model UID: AppleHDA:88 UID: AppleHDAEngineOutput:1B,0,1,2:0
Device #1: ID 0x54 HDMI Manufacturer: Apple Inc. Model UID: AppleHDA:88 UID: AppleHDAEngineOutputDP:1B,3,1,2:0:{EE11-006C-01010101}
Device #2: ID 0x27 Hue Sync Manufacturer: Philips Lighting B.V. Model UID: com_lighting_HueSyncEngine:0 UID: com_lighting_HueSyncEngine:0
UPnP devices found : 3
Device #0: ID 0x0 Denon AVC-X6700H UID: uuid:3316caa1-9db9-1108-0080-00067839c782 Location: http://192.168.1.250:60006/upnp/desc/aios_device/aios_device.xml
Device #1: ID 0x0 210-0024C50023bc UID: uuid:F9420EBC-191F-1241-8925-0024C50023BC Location: http://192.168.1.239:38400/description.xml
Device #2: ID 0x0 Slaapkamer UID: uuid:0be65d64-8d1c-45e1-86b2-f19537049815 Location: http://192.168.1.130:34360/0be65d64-8d1c-45e1-86b2-f19537049815.xml
