Bonjour,
Je n’arrive plus à lire de la musique sur mon Denon CEOL N11 via le réseau WIFI, alors que cela fonctionne bien avec MediaMonkey (v4 ou v5). Le titre du morceau de musique apparaît après un certain temps sur l’écran du Denon, mais la lecture ne démarre pas.
Voici la copie du “Debug info”:
Version actuelle: 1.3.0 (10030)
Bandwidth at 0dB = 99.5%
Phase = 66%
AUTO: D:\Musique
Library database path: C:\Users…\AppData\Local\Audirvana\Audirvana\AudirvanaDatabase.sqlite
Listening on fdaa:bbcc:ddee:0:a116:6302:bd00:b661 on port 63513
Preferred device: Denon Denon CEOL Model UID:Denon Denon CEOL UID:uuid:7a74b6dc-3cd7-16de-0080-00067841ca22
UPnP device at http://192.168.1.11:60006/upnp/desc/aios_device/aios_device.xml
Denon CEOL
Manufacturer: Denon
Model Name:
Model UID: Denon Denon CEOL
UID: uuid:7a74b6dc-3cd7-16de-0080-00067841ca22
Volume control: No
http-get::audio/mpeg:
http-get::audio/x-ms-wma:
http-get::audio/L16;rate=48000;channels=2:
http-get::audio/L16;rate=48000;channels=1:
http-get::audio/L16;rate=44100;channels=2:
http-get::audio/L16;rate=44100;channels=1:
http-get::audio/wav:
http-get::audio/mp3:
http-get::audio/flac:
http-get::audio/aac:
http-get::audio/m4a:
DLNA 1.5: No
Gapless playback: Yes
Missing events workaround: No
Can play native DSD: No
NrTracks: 1
MediaDuration: 00:00:00
CurrentURI: http://192.168.1.8:49152/audirvana/audioTest.pcm
CurrentURIMetadata: dc:titletestTitle</dc:title>http://192.168.1.8:49152/audirvana/audioTest.pcmupnp:classobject.item.audioItem.musicTrack</upnp:class>dc:creator""</dc:creator>upnp:genre""</upnp:genre>upnp:artist""</upnp:artist>upnp:album""</upnp:album>upnp:albumArtURI""</upnp:albumArtURI>
nextURI:
nextURIMetadata:
PlayMedium: NETWORK
<?xml version="1.0"?> 1 0 GetCurrentState CurrentState out LastChange GetCurrentTransportActions InstanceID in A_ARG_TYPE_InstanceID Actions out CurrentTransportActions GetDeviceCapabilities InstanceID in A_ARG_TYPE_InstanceID PlayMedia out PossiblePlaybackStorageMedia RecMedia out PossibleRecordStorageMedia RecQualityModes out PossibleRecordQualityModes GetMediaInfo InstanceID in A_ARG_TYPE_InstanceID NrTracks out NumberOfTracks MediaDuration out CurrentMediaDuration CurrentURI out AVTransportURI CurrentURIMetaData out AVTransportURIMetaData NextURI out NextAVTransportURI NextURIMetaData out NextAVTransportURIMetaData PlayMedium out PlaybackStorageMedium RecordMedium out RecordStorageMedium WriteStatus out RecordMediumWriteStatus GetMediaInfo_Ext InstanceID in A_ARG_TYPE_InstanceID CurrentType out CurrentMediaCategory NrTracks out NumberOfTracks MediaDuration out CurrentMediaDuration CurrentURI out AVTransportURI CurrentURIMetaData out AVTransportURIMetaData NextURI out NextAVTransportURI NextURIMetaData out NextAVTransportURIMetaData PlayMedium out PlaybackStorageMedium RecordMedium out RecordStorageMedium WriteStatus out RecordMediumWriteStatus GetPositionInfo InstanceID in A_ARG_TYPE_InstanceID Track out CurrentTrack TrackDuration out CurrentTrackDuration TrackMetaData out CurrentTrackMetaData TrackURI out CurrentTrackURI RelTime out RelativeTimePosition AbsTime out AbsoluteTimePosition RelCount out RelativeCounterPosition AbsCount out AbsoluteCounterPosition GetTransportInfo InstanceID in A_ARG_TYPE_InstanceID CurrentTransportState out TransportState CurrentTransportStatus out TransportStatus CurrentSpeed out TransportPlaySpeed GetTransportSettings InstanceID in A_ARG_TYPE_InstanceID PlayMode out CurrentPlayMode RecQualityMode out CurrentRecordQualityMode Next InstanceID in A_ARG_TYPE_InstanceID Pause InstanceID in A_ARG_TYPE_InstanceID Play InstanceID in A_ARG_TYPE_InstanceID Speed in TransportPlaySpeed Previous InstanceID in A_ARG_TYPE_InstanceID Seek InstanceID in A_ARG_TYPE_InstanceID Unit in A_ARG_TYPE_SeekMode Target in A_ARG_TYPE_SeekTarget SetAVTransportURI InstanceID in A_ARG_TYPE_InstanceID CurrentURI in AVTransportURI CurrentURIMetaData in AVTransportURIMetaData SetNextAVTransportURI InstanceID in A_ARG_TYPE_InstanceID NextURI in NextAVTransportURI NextURIMetaData in NextAVTransportURIMetaData SetPlayMode InstanceID in A_ARG_TYPE_InstanceID NewPlayMode in CurrentPlayMode Stop InstanceID in A_ARG_TYPE_InstanceID X_SetShuffle InstanceID in A_ARG_TYPE_InstanceID Shuffle in X_Shuffle AVTransportURI string AVTransportURIMetaData string A_ARG_TYPE_CurrentState_AVTransport string A_ARG_TYPE_InstanceID ui4 A_ARG_TYPE_ObjectID string A_ARG_TYPE_SeekMode string TRACK_NR TRACK_NR REL_TIME A_ARG_TYPE_SeekTarget string AbsoluteCounterPosition ui4 AbsoluteTimePosition string CurrentMediaCategory string CurrentMediaDuration string CurrentPlayMode string NORMAL NORMAL REPEAT_ONE REPEAT_ALL CurrentRecordQualityMode string CurrentTrack ui4 0 0 65535 1 CurrentTrackDuration string CurrentTrackMetaData string CurrentTrackURI string CurrentTransportActions string LastChange string NextAVTransportURI string NextAVTransportURIMetaData string NumberOfTracks ui4 0 0 65535 PlayMode ui4 0 PlaybackStorageMedium string PossiblePlaybackStorageMedia string PossibleRecordQualityModes string PossibleRecordStorageMedia string RecordMediumWriteStatus string RecordStorageMedium string RelativeCounterPosition i4 RelativeTimePosition string TransportPlaySpeed string 1 1 12 -12 TransportState string STOPPED STOPPED PAUSED_PLAYBACK PLAYING TRANSITIONING TransportStatus string OK OK ERROR_OCCURRED X_Shuffle boolean 0Current device RootDevice description:
<?xml version="1.0"?> 1 0 urn:schemas-denon-com:device:AiosDevice:1 Denon CEOL Denon http://www.denon.com Denon CEOL Aios 4.025 DBDS082001335 uuid:7a74b6dc-3cd7-16de-0080-00067841ca22 urn:schemas-upnp-org:device:MediaRenderer:1 Denon CEOL Denon http://www.denon.com Denon CEOL Aios 4.025 uuid:d6e1af76-bb92-17e3-0080-00067841ca22 QPlay:1 urn:schemas-upnp-org:service:AVTransport:1 urn:upnp-org:serviceId:AVTransport /upnp/scpd/renderer_dvc/AVTransport.xml /upnp/control/renderer_dvc/AVTransport /upnp/event/renderer_dvc/AVTransport urn:schemas-upnp-org:service:ConnectionManager:1 urn:upnp-org:serviceId:ConnectionManager /upnp/scpd/renderer_dvc/ConnectionManager.xml /upnp/control/renderer_dvc/ConnectionManager /upnp/event/renderer_dvc/ConnectionManager urn:schemas-upnp-org:service:RenderingControl:1 urn:upnp-org:serviceId:RenderingControl /upnp/scpd/renderer_dvc/RenderingControl.xml /upnp/control/renderer_dvc/RenderingControl /upnp/event/renderer_dvc/RenderingControl urn:schemas-denon-com:device:AiosServices:1 AiosServices Denon http://www.denon.com Denon CEOL Aios 4.025 uuid:3b132d3d-af1d-16ab-0080-00067841ca22 urn:schemas-denon-com:service:ErrorHandler:1 urn:denon-com:serviceId:ErrorHandler /upnp/scpd/AiosServicesDvc/ErrorHandler.xml /upnp/control/AiosServicesDvc/ErrorHandler /upnp/event/AiosServicesDvc/ErrorHandler urn:schemas-denon-com:service:ZoneControl:2 urn:denon-com:serviceId:ZoneControl /upnp/scpd/AiosServicesDvc/ZoneControl.xml /upnp/control/AiosServicesDvc/ZoneControl /upnp/event/AiosServicesDvc/ZoneControl urn:schemas-denon-com:service:GroupControl:1 urn:denon-com:serviceId:GroupControl /upnp/scpd/AiosServicesDvc/GroupControl.xml /upnp/control/AiosServicesDvc/GroupControl /upnp/event/AiosServicesDvc/GroupControl urn:schemas-denon-com:device:ACT-Denon:1 Denon CEOL Denon http://www.denon.com Denon CEOL Aios 4.025 DBDS082001335 uuid:cd871548-8ea2-e4bc-8667-06abb0e64919 AIOS:0001 1 167110 Fri 2020-11-27 01:19:02 1.583.162 00:06:78:41:CA:20 en_EU 4 Aios 4.025 1 Production 00:06:78:41:CA:22 urn:schemas-denon-com:service:ACT:1 urn:denon-com:serviceId:ACT /ACT/SCPD.xml /ACT/control /ACT/event urn:schemas-upnp-org:device:MediaServer:1 Denon CEOL Denon http://www.denon.com Shares User defined folders and files to other Universal Plug and Play media devices. Denon CEOL Aios 4.025 DBDS082001335 uuid:d1265a51-814a-c8bc-76db-b0f85c6dca0f True urn:schemas-upnp-org:service:ContentDirectory:1 urn:upnp-org:serviceId:ContentDirectory /upnp/scpd/ams_dvc/ContentDirectory.xml /upnp/control/ams_dvc/ContentDirectory /upnp/event/ams_dvc/ContentDirectory urn:schemas-upnp-org:service:ConnectionManager:1 urn:upnp-org:serviceId:ConnectionManager /upnp/scpd/ams_dvc/ConnectionManager.xml /upnp/control/ams_dvc/ConnectionManager /upnp/event/ams_dvc/ConnectionManagerUPnP devices found : 1
Device #0Denon CEOL UID: uuid:7a74b6dc-3cd7-16de-0080-00067841ca22 Location: http://192.168.1.11:60006/upnp/desc/aios_device/aios_device.xml
Max. memory for audio buffers: 1108MB
Local Audio Engine: ASIO ASIO 0 driver version 0
Device #0: Creative SB/SBX AE DSD ASIO Manufacturer: Model UID: Creative SB/SBX AE DSD ASIO UID: Creative SB/SBX AE DSD ASIO Model Name: Creative SB/SBX AE DSD ASIO
Device #1: Creative SB/SBX AE series ASIO Manufacturer: Model UID: Creative SB/SBX AE series ASIO UID: Creative SB/SBX AE series ASIO Model Name: Creative SB/SBX AE series ASIO
Par avance merci pour votre aide.
Cordialement.
