Thank you for this software which I really like.
I manage my sound library with iTunes and I do not wish to change because I have always liked this software, its “philosophy” since its inception.
I bought AUDIRVANA for its sound performances, including with AAC or ALAC compressed files.
I bought the DENON DNP-800 network player because it is gapless including UPNP and the sound is converted into a PIONEER SC-LX71 amplifier after being oversampled 4 times by AUDIRVANA.
The sound is very good. I use AUDIRVANA in integrated mode with iTunes.
However, I have some problems. Beforehand, I checked that there is no update offered by DENON on the DNP-800:
I can’t navigate inside a song. (never)
Sometimes I listen to a song and it stops without going on to the next one. I delete the iTunes database and redo it to solve this problem. Often it works …
Yesterday, the song from the next album in iTunes started for 1 second when it was not present in the iTunes playlist.
The DNP-800 appears 5 times in UPNP mode. Below the extract from the debug:UPnP devices found : 6
Device #0: ID 0x0 La box Fibre UID: uuid:56066f6e-6b79-4d65-648c-b8ee0e228bc2 Location: http://192.168.0.13:9001/6/TMRDeviceDescription.xml
Device #1: ID 0x0 Denon DNP-800NE UID: uuid:85d7464f-1dbc-12ca-0080-0005cd8b261f Location: http://192.168.0.118:60006/upnp/desc/aios_device/aios_device.xml
Device #2: ID 0x0 Denon DNP-800NE UID: uuid:73f6a036-ae28-1e45-0080-0005cd8b261f Location: http://192.168.0.118:60006/upnp/desc/aios_device/aios_device.xml
Device #3: ID 0x0 Denon DNP-800NE UID: uuid:796c130c-9c13-13e2-0080-0005cd8b261f Location: http://192.168.0.118:60006/upnp/desc/aios_device/aios_device.xml
Device #4: ID 0x0 Denon DNP-800NE UID: uuid:3f56bdda-5687-d94a-82ff-e838620af3af Location: http://192.168.0.118:60006/upnp/desc/aios_device/aios_device.xml
Device #5: ID 0x0 Denon DNP-800NE UID: uuid:a621a708-fe6c-23df-6ad9-fa0bac303f57 Location: http://192.168.0.118:60006/upnp/desc/aios_device/aios_device.xml
I thank you in advance for your help
Romain
Bonjour @RomainB92, merci pour votre message. Lorsque vous vous connectez à votre Denon avec Adirvana vous utilisez le protocole UPnP. Chaque constructeur implémente plus ou moins bien ce protocole en fonction de ses préférences. Si certaines fonctionnalités ne sont pas disponibles alors vous devriez contacter Denon pour leur demander si ils n’ont pas oublié d’ajouter des commandes pour les logiciels UPnP media Renderer. Pour ce qui est de l’apparition de votre DAC en plusieurs fois ce serait lié à HEOS mais je n’ai pas eu de retour de Denon sur le sujet pour le moment.
merci pour ces informations. A l’usage, je crois que je vais plutôt utiliser Audirvana en “stand alone” et non intégré à iTunes, cela règle le problème du début de morceau qui est lu à la fin de la playlist. L’inconvénient est que si je change le nombre d’étoiles sur le morceau, cela ne se répercute pas dans iTunes… Côté qualité sonore, il n’y a pas de différence, n’est ce pas?
Je vous tiens au courant dès que j’ai des infos de la part de Denon.
Il n’y a pas de différences que vous utilisez la synchronisation iTunes ou celle des dossiers de votre musique. Merci d’avoir contacté Denon, cela leur donnera plus de visibilité quand à l’importance de ce problème.
Bonjour Damien,
juste pour vous informer que j’ai fais 2 réclamations auprès de Denon pour leur demander de mettre à jour le lecteur réseau DENON DNP-800 afin qu’il prenne en charge la naviguation à l’intérieur d’un morceau. Ils font suivre au service concerné mais pas de retour…J’ai appris lors de votre passage au PAVS que vous aviez collaboré avec Naim pour rendre leurs produits pleinement conpatibles avec UPNP.
Pourriez vous s’il vous plait vous rapprocher de Denon pour que leurs produits soient enfin pleinement compatibles? Sinon, il serait je pense très utile que les modèles récents grands publics soient référencés sur votre site quand ils sont pleinement compatibles avec Audirvana. Ca motiverait peut-être les fabricants à aller au bout des choses; qu’en pensez vous?
En vous remerciant encore pour ce super logiciel et pour votre retour.
Merci d’avoir fait suivre ce point chez Denon. Nous avons contacté l’équipe en charge de HEOS car il est embarque dans les nouveau systèmes de Denon mais la seul réponse que nous avons eu pour le moment est que nous devons ce mettre en conformité avec leur intégration pour que les nouveau système de Denon fonctionnent correctement (ceci est un processus long qui demandera du temps car nous avons d’autres améliorations à apporter à Audirvana). Il y a d’autres aspects que nous voudrions discuter avec eux mais pour le moment nous n’avons pas eu de réponse. Pour ce qui est de votre dernière demande si nous sommes compatible HEOS, tout les systèmes embarquant HEOS serait compatible Audirvana.
pour moi HEOS ne sert à rien pas plus qu’AirPlay2 car je n’ai jamais éprouvé le besoin de faire du multiroom, je ne recherche que la qualité du son et là UPnP est incontournable en sans fil. Si j’avais su, j’aurais acheté un modèle plus ancien qui n’a pas HEOS. Mais je suis prêt à attendre le temps qu’il faudra pour pouvoir enfin pointer à l’intérieur d’un morceau.
Cordialement
Bonjour,
J’ai la même anomalie dans le debug info avec le lecteur Denon DNP 800 NE qui apparait plusieurs fois. Mais ce qui me gêne le plus c’est qu’Audirvana ne reconnait pas le lecteur comme lisant le DSD en natif alors qu’il le lit jusqu’en DSD 128 via DLNA.
J’ai signalé ces problèmes à Denon et Audirvana à de nombreuses reprises depuis le début de l’année, mais le problème n’est toujours pas résolu!
